840 G3 Bios request
  • slaine
    • Feb 2020
    • 21
    • germany
    840 G3 Bios request
    Hi All,
    in the process of trying to remove the Bios-PW from an 840G3 I somehow F´d up and got a bad Dump. Leaving me with a broken state (power led just flickering or reboot loop with high fan speed and reboot).
    I already tried differnt dumps found in this forum, no luck.
    It looks like those are for the 6050xxx type Mainboard. Mine is a 6070B0883301-A02. If anyone got a clean Main-BIOS dump (16MB) and maybe the EC dump (~8MB) i would be very thankfull if someone could upload it for me to test.
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: 840G3 Bios request
    Post your bios backup here
    • slaine
      • Feb 2020
      • 21
      • germany
      Sorry, the dump is only FF´ed trough the whole area, i think I blew the eeprom while inserting it into the reader (never change the prom while still connected to usb... )
      So I would need a complete cleanME unlocked dump for this machine - MB reads 6070bxxxxxx instead of the 6050xxxx type.. any help appreciated (I cannot even get the prom to read anymore, i ordered a empty one already)
      • Oday91
        • Oct 2022
        • Sweden
        hi i have the same motheboard did you get any help, i also need clean bios file to delet bios admin password without removing the chip.
        • peste
          • Dec 2016
          • 12719
          • ROMANIA
          the bios chip must be removed from the motherboard before reading or writing, or soldered wires between the chip and the programmer, after which we post the bios here...
          https://www.youtube.com/watch?v=DWWigscuQDY
          • Oday91
            • Oct 2022
            • Sweden
            thanks for the answear, is there anyway to remove it whiout need to open the laptop ?
            • peste
              • Dec 2016
              • 12719
              • ROMANIA
              it's not possible.. you got the answer above..
              • swiniks
                • May 2025
                • 3
                • Ukraine
                Please help me remove the BIOS password
                HP EliteBook 840 G3
                Mainboard : 6070B0883301 rev: 1.02 A02
                Damp Lock Pass: Yes
                Download BIOS
                • danito
                  • Jun 2016
                  • 898
                  • Romania
                  HP EliteBook 840 G3
                  Damp Lock Pass: Yes
                  Download BIOS
                  No external links and do it yourself https://www.badcaps.net/forum/troubl...locker?t=98539
                  • swiniks
                    • May 2025
                    • 3
                    • Ukraine
                    Sorry, I couldn't find another way to post the dump. Unfortunately, RCUnlocker doesn't know such a BIOS and Unloker doesn't solve the problem either. Can anyone help?
                      • 20767
                      I have added the file to your post. Your file is 16385KB ,it should be 16384KB ,i suspect that`s why the patcher didn`t work. I think you chose an OTP chip instead of the non OTP ,and that`s why the extra code was added.
                      • swiniks
                        • May 2025
                        • 3
                        • Ukraine
                        I didn't quite understand, I throw the firmware into the exe file RCUnlocker_v_1_0 and get an error message. Firmware size 16.0 MB (16,777,984 bytes)
                        Click image for larger version  Name:	2025-05-07_12-53-04.png Views:	0 Size:	40.2 KB ID:	3631424
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • DynaxSC
                          by DynaxSC
                          11-17-2023, 10:56 AM
                        • grimacelord
                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                          by grimacelord
                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                          Motherboard model number: DA0PAMB46A1 REV: A
                          Secondary motherboard model number: 0PAB
                          SKU: 685K4UA
                          Serial number is: 5CD3223BJP
                          Recently reflashed this laptop with latest BIOS and once...
                          05-07-2024, 08:06 AM
                        • DynaxSC
                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                          by DynaxSC
                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                          11-06-2022, 05:22 PM
                        • TacticalFahrrad
                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                          by TacticalFahrrad
                          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                          06-30-2025, 04:09 AM
