820-3435-a
  • magneh
    • Apr 2014
    • 591
    • Portugal
    820-3435-a
    Hi guys,
    This original bios dump is not working, macbook turns on but no image.
    Tried with a bios chip from same model and it works,but takes long to POST.
    Can someone clear ME this file so I can try?
    Thanks!
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: 820-3435-a
    Originally posted by magneh
    Hi guys,
    Thanks!
    Try and report
    Become a Badcaps supporter
    Thanks to all supporters.
    • magneh
      • Apr 2014
      • 591
      • Portugal
      Re: 820-3435-a
      Thank you
      Will do so.
      Cheers!
      • magneh
        • Apr 2014
        • 591
        • Portugal
        Re: 820-3435-a
        Same thing, board does not boot with this dump.
        Can someone CLEAR ME region of this working dump?
        This is the other 820-3435-A bios chip from another board
        Works but takes 20 secs to boot.
        Also if possible to keep the original SN:C02L31VJF5N7
        Thank you!
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Re: 820-3435-a
          Thank you!
          Why the hell you are posting a dump that doesn't work and asking to clean ME region then?! You think it's a easy two minutes job to clean the ME region? And when the ME is fixed it will work in a magical way? I don't intend to play with it again just because you think so.
          • magneh
            • Apr 2014
            • 591
            • Portugal
            Re: 820-3435-a
            Sorry for that, but the first posted dump was the original that was not posting.
            I dont know if it has been screwed it beforehand.
            Since it did not worked, and to avoid loosing more time, I posted a second one that IS WORKING 100% for sure, only needs the ME region clean.
            Sorry for the waste of time, but I had no way to check the first one.
            But this second dump is working as stated before
              • 21137
              Re: 820-3435-a
              clean bios + SN:C02L31VJF5N7 .
              • magneh
                • Apr 2014
                • 591
                • Portugal
                Re: 820-3435-a
                Thank you so much!
                Mac boots normally; ASD test pass and all is good!
                Have a good one
                • Areos
                  • Jun 2020
                  • 35
                  • México
                  Re: 820-3435-a
                  Thank you!!!
                  • lordmuken
                    • May 2018
                    • 54
                    • Philippines
                    Re: 820-3435-a
                    Hello, can anyone fix my bios? history of unit have corroded bios area(already been rebuild now). my unit boot but kernel panic.
                    i attached my orig bios bin and a bios that is working but with issue.
                    Model: A1465
                    Board Code: 820-3435-A
                    Serial: C02L2EQJF5N7
                    • mmccomputer
                      • 71
                      • France
                      need Unlock EFI MacBook Air A1465
                      Hi
                      Please Need Unlock Efi for Macbook air A1465 MB: 820-3435-A
                      • peste
                        • Dec 2016
                        • 12933
                        • ROMANIA
                        Re: need Unlock EFI MacBook Air A1465
                        Originally posted by mmccomputer
                        Hi
                        try..
                        • bilen
                          • Aug 2014
                          • 638
                          • istanbul
                          Macbook air a1465 password
                          820-3435-a
                          can you remove the password from the original bios?
                          • alihomee
                            • Dec 2012
                            • 1577
                            • malaysia
                            Re: Macbook air a1465 password
                            test and report
                            • CammyTier1
                              Tier 1 Assets
                              • May 2022
                              • 43
                              • bilen
                                • Aug 2014
                                • 638
                                • istanbul
                                Originally posted by alihomee
                                test and report
                                the initial password is gone but it gives this error. I can't install new system
                                • bilen
                                  • Aug 2014
                                  • 638
                                  • istanbul
                                  Originally posted by CammyTier1
                                  asks for password
                                    • 21137
                                    https://www.badcaps.net/forum/showpo...42&postcount=4
                                    3.2.2. 2012 to 2017
                                    For 2012 to 2017 machines, BIOS must be edited and reflashed to clear the password. There are 2 methods for this:
                                    Clear out the whole SVS store. There are other stuff in this store, no idea what they are for so better avoid doing this.
                                    Invalidate the CBF2CC32 NVRAM variable in that SVS store which contains the encrypted password. You just have to change one bit in its name, so like replace the C with an A or whatever. Note that strings are UCS-2 encoded, so in the hex editor it'll show up as 0x43 0x00 0x42 0x00 0x46 0x00 etc.
                                    If there is an iCloud pin, you need to perform 3x PRAM reset after removing password. If FindMyMac is still enabled, you have to reinstall macOS while being disconnected from the Internet, then reconnect after logging in and bind to a new Apple account.
                                    • bilen
                                      • Aug 2014
                                      • 638
                                      • istanbul
                                      3.2.2. 2012 to 2017
                                      thank you king
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • Vesko356
                                        by Vesko356
                                        08-11-2023, 03:27 AM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • Stephen
                                        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                        by Stephen
                                        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                        03-15-2024, 09:37 AM
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
