bios lenovo ideapad 330-15ikb
  • hoaca388
    Badcaps
    • Jan 2022
    • 11193
    • Viet Nam
    Re: bios lenovo ideapad 330-15ikb
    Originally posted by manol278
    please help..
    • than_22
      • Sep 2017
      • 52
      • philippines
      pls repair my bios dump
      lenovo 330-15ikb
      eg521 eg522 ez511 eg721 nm-b452
      problem- No Display
      • hoaca388
        Badcaps
        • Jan 2022
        • 11193
        • Viet Nam
        lenovo 330-15ikb
        problem- no display
        • jimore
          • Nov 2020
          • 177
          • mexico
          Originally posted by marthin
          I leave you a functional taken from the machine for those who need it
          thanks working for me
          • jimore
            • Nov 2020
            • 177
            • mexico
            this isworking bios faster boot
            thanks admin
            • Inforprint
              • Apr 2016
              • 64
              • Brasil
              #26
              Hello everybody.
              I'm in need of help with a Lenovo 330-15IKB-81FE-NM-B452. Mosfet PQ1005 toasted and PQ1001 open and I have already replaced them. Notebook now turns on when plugging in A/C, turns off and on again with 70mA, no video and cooler running at maximum after staying on. (continuous behavior when connecting A/C source). PL1001 without voltage, everything else ok!
              There was oxidation on the PU901 pads, it was removed and resoldered.
              Attached BIOS for analysis and possible ME cleanup.
              Thanks to anyone who can help..
              • peste
                • Dec 2016
                • 12254
                • ROMANIA
                #27
                Originally posted by Inforprint
                Hello everybody.
                I'm in need of some help.
                I am repairing a Lenovo 330-15IKB-81FE-NM-B452. I had a toasted PQ1005 mosfet and an open PQ1001, they were replaced and the notebook now turns on when plugging in A/C, turns off and on again with 70mA (no battery), but without video and cooler firing after turning it on the second time (continuous behavior when plugging in A/C ). PL1001 without voltage, everything else ok! There was PU901 oxidation, it was removed, the pads cleaned and re-soldered.
                Send Bios attached for analysis.
                you have what you need in item # 12
                • Inforprint
                  • Apr 2016
                  • 64
                  • Brasil
                  #28
                  I didn't understand! You say on the PU901?
                  • peste
                    • Dec 2016
                    • 12254
                    • ROMANIA
                    #29
                    use the bios from post # 12 to write your bios chip ...
                    • Inforprint
                      • Apr 2016
                      • 64
                      • Brasil
                      #30
                      Hello Peste!
                      I tried, but with no good results.
                      I still have no voltage on the PL1001, with a resistance of 7.5ohms. PU 1001 is 2.0V pwm, and according to this datasheet (NCP81253) the output is low, but I don't know if it would be normal on the NM-B452.
                      In the PL 1002/1003 connected I have 0.853V in both, with a resistance of 0.2 Ohms. Processor heats up normally, but the board always turns on when plugging in the power supply, turns it off and on again keeping 0.77mA and fan at maximum after a few seconds.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11193
                        • Viet Nam
                        #31
                        Hello Peste!
                        330-15IKB (Type 81FE)
                        • m.maher
                          • 21
                          • egypt
                          #32
                          Lenovo IdeaPad 330-15IKB DMI Info
                          Hello everybody How can I get the dmi info for the Lenovo IdeaPad 330-15IKB. and what's the role of finding the dmi info on a variable bios bin
                          • sarkov
                            • Aug 2016
                            • 12
                            • Spain
                            #33
                            hello guys, I am attaching a bios of a lenovo that when turned on after a few seconds goes by turns off again, I have doubts that the bios is the cause but anyway I would appreciate if someone can correct the backup that I attach, thanks
                            • lapfix
                              • Mar 2020
                              • 2576
                              • my workshop
                              #34
                              try
                              • javben
                                • May 2013
                                • 11
                                • spain
                                #35
                                Hello. I have a lenovo ideapad 300-15IKB TYPE:81DE.MB 451 that has been previosuly serviced not too god im afraid
                                I have tried to use this file:
                                Can someone confirm
                                1.- original bios chip is W25q64 type?
                                2.- Is anyone able to upload a clean dump for it?
                                Regards and thanks in advance
                                • lapfix
                                  • Mar 2020
                                  • 2576
                                  • my workshop
                                  #36
                                  Can someone confirm
                                  post your old dump
                                  • Nordlig
                                    • Oct 2022
                                    • 6
                                    • Spain
                                    #37
                                    I used this BIOS and it worked nice, thank you very much!
                                    I have dumped the same bios.bin to 5 laptops ideapad 330 and everyone worked perfect.
                                    How can I barecode the serial number, UUID, Computer Name for each laptop? (in the BIOS it says INVALID to these fields).
                                    Every tool I tried does not work (H2oEZE, H2OSDE, Lenovo manteinance Disk). Is possible to unlock the EEPROM or edit the BIOS file before dumping it to a laptop? I tried UEFITools either but no success.
                                    Thanks in advance
                                    • peste
                                      • Dec 2016
                                      • 12254
                                      • ROMANIA
                                      #38
                                      Thanks in advance
                                      at post #12 you have the interval where you find the DMI information... use the HxD program.. enter the original bios and the bios extracted from the update on the website in HxD and copy this interval from one bios to the other..
                                      • Nordlig
                                        • Oct 2022
                                        • 6
                                        • Spain
                                        #39
                                        Hello Peste,
                                        Thank you for the response. I'm pretty new on this and I have no clue where is the DMI stored, I have to know the offset or address range to extract that DMI you mention before, right?
                                        Where or how can I find/know the hexadecimal range of the DMI you mention in the BIOS file? I tried but I get lost on that huge amount of hex numbers, I tried to find somethin like "serial", "uuid", but no success at all...
                                        Thank you
                                        • peste
                                          • Dec 2016
                                          • 12254
                                          • ROMANIA
                                          #40
                                          Hello Peste,
                                          Thank you
                                          The DMI is in the interval from post#12
                                          DMI 234000 - 235FFF
                                          on this laptop model the DMI is coded..
                                          enter both bios in the HxD program, search the original bios by the word (LENV), check the box and transfer this interval with (copy-paste) to the other bios...
                                          • mximiliandz
                                            help bios lenovo ideapad s145-14iil type 81w6
                                            by mximiliandz
                                            Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                            06-20-2025, 06:50 AM
                                          • jendkkd jeje
                                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                            by jendkkd jeje
                                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                            10-11-2024, 03:12 PM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • grimacelord
                                            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                            by grimacelord
                                            Hello there.
                                            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                            History:
                                            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                            I searched for this error online and discovered...
                                            03-15-2023, 03:29 PM
                                          • Popel1083
                                            Lenovo IdeaPad U330p Read Bios than Bios Password Remove
                                            by Popel1083
                                            I want to remove the Bios Password of my Lenovo IdeaPad U330p with the Lenovo autopatcher. I have the CH341A Black and I'm using NeoProgrammer. The Programmer has an LED that indecates when it reads or writes the Chip. When I try to Connect my Programmer to the Bios Chip (Winbond 25Q64FVSIQ) the LED lights up even though I didn't click on Detect botton in NeoProgrammer. If i click on Detect the LED still remains on and NeoProgrammer says "IC not responding".
                                            SN: QB08570065
                                            MB: DA0LZ5MB8D0; REV: D; MODEL J31/N02
                                            08-06-2024, 05:52 PM
