I NED Lenovo Y50-70 LA-B111P BIOS
Tags: None
Re: I NED Lenovo Y50-70 LA-B111P BIOS
.Comment
Hum, missing message or attachment?OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
No. I moved the posts to the Bios Requests section and made a new thread,they were tagged onto another thread in the main laptop forum (just the usual crap,asking for a bios/schematic in the wrong place). As you know if you move a thread you can leave a redirect,if you move posts out to a new thread you can`t. Members won`t know their posts have been moved to a new thread unless you leave a reply, or send a PM .Last edited by SMDFlea; 08-09-2022, 08:01 AM.Comment
y50-70
hi
i have this bios with password
can you unlock it?
thanksAttached FilesComment
Re: y50-70
password removed, update bios to the latest one because you have a very old oneAttached FilesComment
Re: Lenovo Y50-70 LA-B111P - I need BIOS
read this..
post the original biosDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
There was no reaction on the device, I did my checks, the voltages are normal. I tried the shared bios here. My device got triggered, but it stays at 1amp and does not display. Can you repair my bios or share a working bios for me. Thanks.
Y50-70
20378
LA-B111P Rev:1.A
Nvidia GpuAttached FilesComment
Y50-70 Laptop (Lenovo) - Type 80EJThere was no reaction on the device, I did my checks, the voltages are normal. I tried the shared bios here. My device got triggered, but it stays at 1amp and does not display. Can you repair my bios or share a working bios for me. Thanks.
Y50-70
20378
LA-B111P Rev:1.A
Nvidia Gpu↵
https://www.badcaps.net/donateComment
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... - Loading...
