LENOVO 320 NM-B321 bios needed
  • String2016
    • Nov 2015
    • 2229
    • philippines
    I need a main and ec bios on this lenovo idepad 320, I tried the bios on this forum not working turns on no display here is my backup bios file please help
    • 20473
    Re: LENOVO 320 bios needed
    Which bios did you try .
    • String2016
      • Nov 2015
      • 2229
      • philippines
      thanks smdflea for the response this is the bios i try https://www.badcaps.net/forum/showth...hlight=NM-B321
        • 20473
        That bios is 100% good,it was extracted from the official bios update. Your problem is somewhere else .
        • String2016
          • Nov 2015
          • 2229
          • philippines
          That is why i need EC for this do you have this please, Ill try to program the LENOVO CHIP IT8586E. because base from the clients this laptop leaves battery drain then when charge again this happens turn on no display.
          • String2016
            • Nov 2015
            • 2229
            • philippines
            I need a working EC on this please
              • 20473
              Here, its extracted from the bios at that link from @mcplslg.
              • String2016
                • Nov 2015
                • 2229
                • philippines
                thanks SMDFLEA, I try this and report back
                • String2016
                  • Nov 2015
                  • 2229
                  • philippines
                  Tried program EC still the same issue turns on lights shows but cpu fan is not spinning
                    • 20473
                    Then your problem is somewhere else.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Why not try diagnosing the fault?? All problems are not bios related. Start by measuring voltage on all big coils as well as resistance on those coils.
                      • Wahaz
                        by Wahaz
                        10-30-2023, 08:42 PM
                      • grimacelord
                        by grimacelord
                        Hello there.
                        History:
                        03-15-2023, 03:29 PM
                      • cyber16
                        Lenovo P1 g1 Type 20MD-002PUS "BIOS Help Needed"
                        by cyber16
                        Please I need help.
                        Quick rundown long story shorter, but still long winded.
                        I received this Lenovo P1 GEN 1 about a year ago from a business.
                        It was pretty much dead hit the power button and the LED on the power light would come on as would the keyboard back light a couple times and just shut off or go into high speed fan mode without life other than the power button led.
                        At that time it was still under warranty, I spoke to Lenovo and I was going to send it in to have them repair it.
                        Then late last fall my father-in-law suffered...
                        09-08-2022, 07:32 AM
                      • Joluvillas
                        Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                        by Joluvillas
                        Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                        06-18-2024, 10:35 PM
                      • baaligoga
                        Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                        by baaligoga
                        Good day, everyone!
                        I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                        I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                        05-20-2023, 09:48 AM
