dell l502x gm6b
  • JustX
    • Feb 2019
    • 72
    • iran
    dell l502x gm6b
    hello i need bios ec for this laptop
    DAGM6BMB8F0 REV:F
    thank you
    • 22277
    Re: dell l502x gm6b
    https://www.badcaps.net/forum/showthread.php?t=48882
    • JustX
      • Feb 2019
      • 72
      • iran
      Re: dell l502x gm6b
      thank you.
      but this one is gm6c and ec size is 512kb mine is gm6b with 1mb ec size
        • 22277
        Re: dell l502x gm6b
        Here`s the same EC padded out to 1MB .
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Re: dell l502x gm6b
          Are you sure your model is L502X and not L501X?? The bios for both platform is totally different.
          L502X=Quanta GM6C mb, Intel HM65 Chipset
          L501X=Quanta GM6B Mb, Intel HM55 Chipset
          Try the bios attached. Its specific to HM55 Chipset Quanta GM6B Mb. Verify the mb code first.
          • jbaht
            • Jan 2021
            • 7
            • Gabon
            Re: dell l502x gm6b
            hello urgently need bios dell L502X GM6C
            intel chipset HM67
            THANK YOU
            • peste
              • Dec 2016
              • 13924
              • ROMANIA
              Re: dell l502x gm6b
              Originally posted by jbaht
              bonjour besoin urgent bios dell L502X GM6C
              intel chipset HM67
              MERCI
              have you tried post # 2 ?? don't forget to make a backup of the bios before writing ..
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • Akhlz001
                by Akhlz001
                09-20-2025, 07:15 PM
              • master3112
                by master3112
                07-29-2025, 01:55 PM
              • sahamipoor
                how to Set graphic Discrete mode motherboard(no UMA) Dell XPS L502x - DAGM6CMB8D0
                by sahamipoor
                hello...
                the Dell XPS L502x ( Model P11F ) [ DAGM6CMB8D0 rev.D ..3 of lines output LVDS from PCH has short ohm(0 -70) than LCD displat turn ON but is white !!!
                i decide to change LVDS ports to Lcd from EXT_LCD graphic Studio Discrete to No need it LVDS lines of PCH use...
                according to ُSchematic ,I changed any resistor and... Config_0 and Config_1 EC...but:
                1- EXT_LCD_PWM no voltage to enable pwm
                2-EXT_LVDS_VDDEN no High to Enable LCD_vcc
                and screen is turn off and fan is high Speed!!
                Question:
                I need to Use Discrete graphic nvidia EXT_LCD ports...
                03-12-2024, 02:51 AM
                Dell Thunderbolt Firmware
                by SMDFlea
                Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                The SKU is in brackets (****)
                EDIT: NVM65...
                01-26-2025, 06:22 AM
