HP Probook 450 G1 bios - tested
  • vienas111
    • Dec 2018
    • Lithuania
    Re: HP Probook 450 G1 bios - tested
    Can anybody help me with this BIOS?
    No picture and fan spins max.
    I have try other BIOS dumps, but on laptop startup got green screen or grey to white. After Ctrl+Alt+Del picture starts normal. Maybe its graphics isue?
    • hoaca388
      Badcaps
      • Jan 2022
      • 12281
      HP ProBook 450 G1 Notebook PC
      • laptopbn
        • Jul 2016
        • 72
        • Viet Nam
        Originally posted by SMDFlea
        The bios at post 1 has the wrong flash descriptor,its set to 2 SPI chips and the other settings are all over the place, don`t use that bios.The bios at post 2 isn`t recommended either ,wrong settings. @peste ,compare our 2 bios with FITC,see the differences.
        Try this fixed bios with your DMI and clean ME.
        thanks
        • fraig
          • Nov 2014
          • 36
          • cairo
          Originally posted by smdflea
          the bios at post 1 has the wrong flash descriptor,its set to 2 spi chips and the other settings are all over the place, don`t use that bios.the bios at post 2 isn`t recommended either ,wrong settings. @peste ,compare our 2 bios with fitc,see the differences.
          Try this fixed bios with your dmi and clean me.
          you save my day thank you
          • almussafer
            • Jun 2019
            • 82
            • Iraq
            thanks pro its work
            • kamkooltech
              kamkooltech
              • Jun 2019
              • 123
              • nigeria
              #26
              Hello boss, how to figure out the right DMI Tool for specific generations.
              For samples HP ProBook 450 G2 compatible DMI Tool??
              I want to learn boss
              • alien2108
                • Apr 2024
                • Slovenia
                #27
                The bios at post 1 has the wrong flash descriptor,its set to 2 SPI chips and the other settings are all over the place, don`t use that bios.The bios at post 2 isn`t recommended either ,wrong settings. peste ,compare our 2 bios with FITC,see the differences.
                Thank you vert much, worked on 450 G1! I had to take the chip out since it did not work with the clip. Even after taking it out it did not work properly with the clip, I had to solder it to the DIP adapter.
                • Sparklingx
                  • Jul 2024
                  • 41
                  • Bangladesh
                  #28
                  I have a HP probook 450 g1(intel i5 with AMD radeon graphics) I do not have original bios. Someone flashed a bios which decreased performance(slow startup) and has admin pass in BIOS. Can someone tell me where can I get a bin(bios) for this laptop?
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    #29
                    Can you share your unit serial number and the motherboard code or model
                    • Sparklingx
                      • Jul 2024
                      • 41
                      • Bangladesh
                      #30
                      Hi pls pardon my late reply, there was political turmoil and massive internet shutdown(a long time) in my country and I was also busy irl.
                      Here is full details(photo attached)
                      Hp probook 451 g1 (intel i5 + AMD radeon dedicated graphics)
                      motherboard code: Rampage_MB 12241-1 48.4YW05.011
                      Unit serial no: 8CG421120S
                      product: F4W80PA#UUF
                      • danito
                        • Jun 2016
                        • 1074
                        • Romania
                        #31
                        Try
                        • Sparklingx
                          • Jul 2024
                          • 41
                          • Bangladesh
                          #32
                          danito is this the original bios? and is the password clear? and is it 48.4YW03.011 or 48.4YW05.011?
                          • danito
                            • Jun 2016
                            • 1074
                            • Romania
                            #33
                            48.4YW05.011, original file, I don't think he has the password.
                            • studdy05
                              Bricked HP Probook 450 G7 Bios questions
                              by studdy05
                              Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                              Ive got...
                              07-08-2025, 09:24 PM
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • Vesko356
                              by Vesko356
                              08-11-2023, 03:27 AM
                            • the_raz
                              Need (unlocked) bios for HP Probook 450 G3 Notebook
                              by the_raz
                              I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                              Laptop number 1:
                              Model: HP ProBook 450 G3
                              Motherboard part number:...
                              12-17-2024, 03:37 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
