HP Probook 470 G5 DA0X8CMB6E0 BIOS X8C
  • cesaro
    • 28
    • N/A
    #61
    it's working , thank you a lot
    have a nice day
    • RuslanOrlov
      • Sep 2025
      HP ProBook 470 G5 DA0X8CMB6E0
      Cant get to boot my laptop. Only Caps and NumLock blinks for 5 times
      my laptop is with Nvidia GPU
      it happened years before after a Windows update. Now I have a programmer and try to fix it
      Can someone help?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12086
        #63
        Can someone help?
        You MUST:
        • Read BIOS guides, methods, resources and tools
        • Try the method at BIOS guides, methods, resources and tools before requesting help
        • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
        • Use search function in case someone already answered your request
        • Post under a related thread if it exists
        • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
        • Name your thread with make, full model numbers and request
        • Provide a BIOS/EC dump if possible
        • Attach files directly to your post instead of linking to external websites
        • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • ktcar214
          Need help for HP ProBook 445R G6 Secure boot key removal from BIOS dump
          by ktcar214
          Hello.
          I tried to add a custom secure boot key (for secure booting Linux) to my bios, but after this, my laptop bricked. After adding secure boot key (via PowerShell) and enabling secure boot my laptop turns on, shows HP logo, and after 5 seconds it turns off and on, and it repeats forever.
          My goal is to either turn off secure boot or remove my custom key from BIOS dump.
          I'll attach my bios dump (version R79_011700) from my bios chip 25b127dsig, my keys (PK/KEK/db), and bios dump from another HP ProBook 445R G6(I found it on this forum. URL: https://www.ba...
          12-07-2021, 08:57 AM
        • q2v5
          Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
          by q2v5
          Lenovo T480s
          Model 20L8-S3TE00
          Board ET481-U10
          Chip MX25L12873F
          Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
          2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
          The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
          08-15-2024, 10:40 PM
        • Neddsme
          Bios partially corrupted somehow and now warm boot doesn't work which is critical
          by Neddsme
          Hie.
          I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
          Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
          I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
          I managed to run Windows troubleshooting and...
          02-04-2022, 05:57 AM
        • Max029
          Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
          by Max029
          I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
          I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
          TY,
          08-18-2024, 08:28 PM
