Laduree-SKY MB 448.06202.0011 14263-1 BİOS
  • ahmetermin
    • Mar 2015
    • 38
    • batman
    HP 15t-w200
    BİOS BACKUP BŞOS PASWWORD
    http**************RxNaN3oQ
  • adnanadan1
    • Feb 2019
    • 46
    • pakistan
    Re: Laduree-SKY MB 448.06202.0011 14263-1 BİOS
    • ahmetermin
      • Mar 2015
      • 38
      • batman
      Thank you test ok
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        HP ENVY x360 Laduree-SKY MB 14263-2 448.06202.001
        Hope someone can help me with my issue laptops sometimes display but if you leave it for a day it wont display again ..
        Hope somone can fix my bios
        HP 15-BK157CL
        S/N: 8CG7010VS1
        P/N:X7Q92UA#ABA
          • 21692
          Re: HP ENVY x360 Laduree-SKY MB 14263-2 448.06202.001
          HP 15-BK157CL
          S/N: 8CG7010VS1
          P/N:X7Q92UA#ABA
          Open your bios with a hex editor,search for the word BID .Your BID is 08251 .Go to the HP support site,enter the serial number.Download the bios,run the exe and choose to Save to a location (a folder) .The full 08251 virgin bios will be extracted. You can flash that but you will lose all DMI info.
          Using a hex editor copy the DMI from your backup to the virgin bios. I will tell you what the offsets are,only if you are interested in fixing your own bios, rather than have someone do it for you every time.
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            I already exctracted the bios bin file from teh software , using winrar. Yes im very interested.
              • 21692
              ok ,see the attached picture for the offsets
              • hoaca388
                Badcaps
                • Jan 2022
                • 12281
                @SMDFlea : With some exe files from Hp I can't run it even with older versions, is this a windows problem ? I am using win 10 pro, 64bit, 21H2.
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  Try windows 7 it happen to me like that also
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    Im sorry im a bit lost, after getting the ofset? I need to create a new file and paste it right? after that what should I do?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12281
                      Just copy and paste. ( Crtl + B )
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        then jsut flashed the bin?
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12281
                          First you have to see if the file extracted from the exe file is a complete file using the UEFI tool. Usually, the complete bios file will start with the Description area and end with the Bios area. If it's a complete file, just overwrite the DMI block with its exact offset.
                          In case the extracted file is just the bios region part, you have to specify the starting offset of the bios region in the old bios, overwriting the new bios region. In case the extracted file has only bios region and excess offsets, you have to cut off those extra offsets and then do the same as the second case.
                          • kalilinux25
                            • Mar 2018
                            • 2089
                            • ZAMBOANGA SIBUGAY
                            im very confused on how can I tell where is the offset of the original and the new bios
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12281
                              I take the example with Dell XPS 9500
                                • 21692
                                There`s a picture at post #7 the virgin bios is on the left,your backup on the right.Just use a hex editor don`t use UEFITool,keep things as easy as possible.Enter the offsets in your backup to select the area 220000 - 221FFF (Length 2000) ,select copy,then enter the exact same offsets in the virgin bios and choose paste-insert,then save.
                                • kalilinux25
                                  • Mar 2018
                                  • 2089
                                  • ZAMBOANGA SIBUGAY
                                  Thanks sir I've flashed the bios bin but How can I tell the DMI offset?
                                  • Infinity13197
                                    • Sep 2020
                                    • 20
                                    • Nigeria
                                    Re: Laduree-SKY MB 448.06202.0021 14263-2 BİOS
                                    Laduree-SKY MB 14263-2 448.06202.0021 USB not detecting device's, pls help me edit it.
                                    HP-w158ca
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      HP-w158ca
                                      https://www.badcaps.net/forum/showthread.php?t=103526
                                      6. Finding bios update packages
                                      6.1.8 HP
                                      See:
                                      [Guide] How to extract ready for programming dump from HP update executable file
                                      https://www.badcaps.net/forum/showthread.php?t=121948
                                      https://www.badcaps.net/forum/showth...51#post1261151
                                      When you`ve found and extracted the right bios using the guides above you can add the DMI (serial number,featurebyte etc) and Windows key to the new bios using following offsets
                                      Become a Badcaps supporter
                                      Thanks to all supporters.
                                      • Infinity13197
                                        • Sep 2020
                                        • 20
                                        • Nigeria
                                        laduree-sky mb 14263-2 448.06202.0021
                                        Some should help me and download this exact same file, my credit on premium side has finished will really and very much appreciate if I can get it as soon as possible!!
                                          APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
                                          This started a few days ago and does this about every 8 hours
                                          After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
                                          The battery backup is about 3 or 4 years old
                                          Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
                                          06-02-2024, 02:30 AM
                                        • Chris_stand
                                          Clevo PD50PNN won't boot after BIOS Backup
                                          by Chris_stand
                                          i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
                                          At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
                                          Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
                                          But the...
                                          04-28-2023, 03:08 PM
                                        • DiddiAb
                                          BIOS Backup / extract 16MB .bin - Lenovo ThinkBook 13s G3 ACN - 20YA0005GE
                                          by DiddiAb
                                          Recently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
                                          I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...
                                          03-11-2023, 03:15 AM
                                        • shadow666
                                          Lenovo Y520 NM-B191 U115 Backup
                                          by shadow666
                                          i have a Lenovo Legion Y520
                                          I programmed the 8MB Bios & 1MB ME on the laptop by mistake
                                          i have 8MB Bios Backup but i don,t have 1MB ME Backup
                                          after programed Bios with 4 or 5 Different ME Laptop Turn on but after 10 Second is boot
                                          I cleaned the ME bios part of 8MB by using MEinject software, but it didn't make any difference and the system will boot again after 10 seconds.
                                          i know this for 1MB ME
                                          my Bios Version is 4KCN45WW
                                          Someone has a backup of this version of ME to upload here ?
                                          i Need A Backup of 25q80dv U115 backup from 4KCN45WW...
                                          09-13-2022, 07:59 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          Hi everyone
                                          09-06-2025, 05:47 PM
