Laduree-SKY MB 448.06202.0011 14263-1 BİOS
  • ahmetermin
    • Mar 2015
    • 38
    • batman
    HP 15t-w200
    BİOS BACKUP BŞOS PASWWORD
    http**************RxNaN3oQ
  • adnanadan1
    • Feb 2019
    • 46
    • pakistan
    Re: Laduree-SKY MB 448.06202.0011 14263-1 BİOS
    • ahmetermin
      • Mar 2015
      • 38
      • batman
      Thank you test ok
      • kalilinux25
        • Mar 2018
        • 2069
        • ZAMBOANGA SIBUGAY
        HP ENVY x360 Laduree-SKY MB 14263-2 448.06202.001
        Hope someone can help me with my issue laptops sometimes display but if you leave it for a day it wont display again ..
        Hope somone can fix my bios
        HP 15-BK157CL
        S/N: 8CG7010VS1
        P/N:X7Q92UA#ABA
          • 20404
          Re: HP ENVY x360 Laduree-SKY MB 14263-2 448.06202.001
          HP 15-BK157CL
          S/N: 8CG7010VS1
          P/N:X7Q92UA#ABA
          Open your bios with a hex editor,search for the word BID .Your BID is 08251 .Go to the HP support site,enter the serial number.Download the bios,run the exe and choose to Save to a location (a folder) .The full 08251 virgin bios will be extracted. You can flash that but you will lose all DMI info.
          Using a hex editor copy the DMI from your backup to the virgin bios. I will tell you what the offsets are,only if you are interested in fixing your own bios, rather than have someone do it for you every time.
          • kalilinux25
            • Mar 2018
            • 2069
            • ZAMBOANGA SIBUGAY
            I already exctracted the bios bin file from teh software , using winrar. Yes im very interested.
              • 20404
              ok ,see the attached picture for the offsets
              • hoaca388
                Badcaps
                • Jan 2022
                • 11331
                • Viet Nam
                @SMDFlea : With some exe files from Hp I can't run it even with older versions, is this a windows problem ? I am using win 10 pro, 64bit, 21H2.
                • kalilinux25
                  • Mar 2018
                  • 2069
                  • ZAMBOANGA SIBUGAY
                  Try windows 7 it happen to me like that also
                  • kalilinux25
                    • Mar 2018
                    • 2069
                    • ZAMBOANGA SIBUGAY
                    Im sorry im a bit lost, after getting the ofset? I need to create a new file and paste it right? after that what should I do?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11331
                      • Viet Nam
                      Just copy and paste. ( Crtl + B )
                      • kalilinux25
                        • Mar 2018
                        • 2069
                        • ZAMBOANGA SIBUGAY
                        then jsut flashed the bin?
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11331
                          • Viet Nam
                          First you have to see if the file extracted from the exe file is a complete file using the UEFI tool. Usually, the complete bios file will start with the Description area and end with the Bios area. If it's a complete file, just overwrite the DMI block with its exact offset.
                          In case the extracted file is just the bios region part, you have to specify the starting offset of the bios region in the old bios, overwriting the new bios region. In case the extracted file has only bios region and excess offsets, you have to cut off those extra offsets and then do the same as the second case.
                          • kalilinux25
                            • Mar 2018
                            • 2069
                            • ZAMBOANGA SIBUGAY
                            im very confused on how can I tell where is the offset of the original and the new bios
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11331
                              • Viet Nam
                              I take the example with Dell XPS 9500
                                • 20404
                                There`s a picture at post #7 the virgin bios is on the left,your backup on the right.Just use a hex editor don`t use UEFITool,keep things as easy as possible.Enter the offsets in your backup to select the area 220000 - 221FFF (Length 2000) ,select copy,then enter the exact same offsets in the virgin bios and choose paste-insert,then save.
                                • kalilinux25
                                  • Mar 2018
                                  • 2069
                                  • ZAMBOANGA SIBUGAY
                                  Thanks sir I've flashed the bios bin but How can I tell the DMI offset?
                                  • Infinity13197
                                    • Sep 2020
                                    • 19
                                    • Nigeria
                                    Re: Laduree-SKY MB 448.06202.0021 14263-2 BİOS
                                    Laduree-SKY MB 14263-2 448.06202.0021 USB not detecting device's, pls help me edit it.
                                    HP-w158ca
                                    • Vesko356
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      HP-w158ca
                                      https://www.badcaps.net/forum/showthread.php?t=103526
                                      6. Finding bios update packages
                                      6.1.8 HP
                                      See:
                                      [Guide] How to extract ready for programming dump from HP update executable file
                                      https://www.badcaps.net/forum/showthread.php?t=121948
                                      https://www.badcaps.net/forum/showth...51#post1261151
                                      When you`ve found and extracted the right bios using the guides above you can add the DMI (serial number,featurebyte etc) and Windows key to the new bios using following offsets
                                      Become a Badcaps supporter
                                      Thanks to all supporters.
                                      • Infinity13197
                                        • Sep 2020
                                        • 19
                                        • Nigeria
                                        laduree-sky mb 14263-2 448.06202.0021
                                        Some should help me and download this exact same file, my credit on premium side has finished will really and very much appreciate if I can get it as soon as possible!!
                                        • chth96
                                          How Can I test PWM DM0365R?
                                          by chth96
                                          Hello
                                          I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                          So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                          I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                          I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                          06-18-2025, 04:14 PM
                                        • GameKinq
                                          6-71-nj5l0-d02 - exa nj51lu backup test ok
                                          by GameKinq
                                          6-71-NJ5L0-D02 - EXA NJ51LU BACKUP TEST OK
                                          SRG0S (Intel Core i3-1005G1)-CPU...
                                          05-31-2022, 07:55 PM
                                        • khelane
                                          test active pfc power with lamp test
                                          by khelane
                                          Hello
                                          I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                          Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                          Is there a way...
                                          06-03-2025, 01:00 AM
                                        • chronic519
                                          Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                                          by chronic519
                                          Hello.
                                          GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                                          Found issue with a RAM block
                                          Replaced, green lines gone.
                                          Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                                          Used a good card to test and same results low errors 32+.
                                          I am just search for some form of command to do a full test on the GPU.
                                          I just ran the mats command with my good GPU and passed after roughly 40 min.
                                          The repaired one, ran...
                                          05-20-2025, 07:56 PM
                                          APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
                                          by sam_sam_sam
                                          This started a few days ago and does this about every 8 hours
                                          After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
                                          The battery backup is about 3 or 4 years old
                                          Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
                                          06-02-2024, 02:30 AM
