pleases bios hp DAY0HGMB6C1 REV-C
Re: pleases bios hp DAY0HGMB6C1 REV-C
thx for reply
this is the link "DAY0HGMB6C1 REV C backup"
https://mega.nz/#!FxwXAYIY!jgD7RvCOV...weoQKSSYaZmW-ULast edited by baothmen; 02-08-2020, 05:47 AM.Comment
Re: bios hp DAY0HGMB6C1 REV-C
There is no update on hp site for this bios. Sorry cant help as i dont have a working dump either. maybe someone else can share.Comment
if someone have a bios backup of this board DAY0HGMB6C1 REV C pls share thank you i hope someone can help us thank youComment
Here
Techman1025Attached Filesif you find these attachements useful please consider making a small donation to the site
can you edit or fix my bios? the one you share is not working for me. big thanks Techman1025Attached Filesif you find these attachements useful please consider making a small donation to the site
can someone fix my hp bios DAY0HGMB6C1 REV: C this is my backup
thanks you in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
I ran into the same problem with the same mobo from an HP Stream 11 (11-ah117wm). At one point I gave up and tried to search for a replacement mobo on Ebay. I then came across a mobo that looked just like it but had an older Celeron CPU and DDR3 ram. It was an HP Stream 11 Pro G3. Well, searching for a Pro model with DD4 ram led me to the G5, and flashing its bios was a success!
It can be downloaded from here:
https://support.hp.com/us-en/drivers...ok-pc/21949282Comment
hello friend I have bios can I remove password?
HP Stream - 11-ah117wmAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: HP Stream 11-ah117wm remove password
First, read this: https://www.badcaps.net/forum/showthread.php?t=103570, you have two posts.
Next, if you get the i XXXXXXXX digit challange code, read and unlock it yourself:
https://www.badcaps.net/forum/showpo...3&postcount=59Comment
by DiddiAbRecently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...-
Channel: BIOS Requests ONLY!
Product Name: Razer Blade 15 (2022)
Product ID: RZ09-0421
Motherboard: CH580
BIOS Versions I work with: 2.02 & 2.06
Bios File Size: 32,768 KB
Dear Forum Readers!
I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
!!! MY RAZER BLADE...-
11-24-2025, 05:52 PM -
by Chris_standHello,
i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
But the...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
