bios hp DAY0HGMB6C1 REV-C
  • baothmen
    • May 2019
    • 15
    • tunisia
    pleases bios hp DAY0HGMB6C1 REV-C
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: pleases bios hp DAY0HGMB6C1 REV-C
    Post your backup bios here.
    • baothmen
      • May 2019
      • 15
      • tunisia
      thx for reply
      this is the link "DAY0HGMB6C1 REV C backup"
      https://mega.nz/#!FxwXAYIY!jgD7RvCOV...weoQKSSYaZmW-U
      • baothmen
        • May 2019
        • 15
        • tunisia
        plz bios hp DAY0HGMB6C1 REV-C
        "Attached Files"
        thx for reply
        • baothmen
          • May 2019
          • 15
          • tunisia
          Re: bios hp DAY0HGMB6C1 REV-C
          up
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            There is no update on hp site for this bios. Sorry cant help as i dont have a working dump either. maybe someone else can share.
            • baothmen
              • May 2019
              • 15
              • tunisia
              thank you
              • Blackpanther135
                • Aug 2020
                • 6
                • Philippines
                if someone have a bios backup of this board DAY0HGMB6C1 REV C pls share thank you i hope someone can help us thank you
                • Blackpanther135
                  • Aug 2020
                  • 6
                  • Philippines
                  what is the problem of your bios?
                  • techman1025
                    • Jun 2014
                    • 497
                    Here
                    Techman1025
                    • Blackpanther135
                      • Aug 2020
                      • 6
                      • Philippines
                      Originally posted by techman1025
                      Here
                      Techman1025
                      can you edit or fix my bios? the one you share is not working for me. big thanks Techman1025
                      • Blackpanther135
                        • Aug 2020
                        • 6
                        • Philippines
                        can someone fix my hp bios DAY0HGMB6C1 REV: C this is my backup
                        thanks you in advance
                        • peste
                          • 13924
                          • ROMANIA
                          post the full name and model of the laptop
                          • Blackpanther135
                            • Aug 2020
                            • 6
                            • Philippines
                            HP Steam 11-ah110nr
                            • Blackpanther135
                              • Aug 2020
                              • 6
                              • Philippines
                              HP Steam 11-ah110nr
                              up
                              • gelidd
                                • May 2021
                                • 6
                                I ran into the same problem with the same mobo from an HP Stream 11 (11-ah117wm). At one point I gave up and tried to search for a replacement mobo on Ebay. I then came across a mobo that looked just like it but had an older Celeron CPU and DDR3 ram. It was an HP Stream 11 Pro G3. Well, searching for a Pro model with DD4 ram led me to the G5, and flashing its bios was a success!
                                It can be downloaded from here:
                                https://support.hp.com/us-en/drivers...ok-pc/21949282
                                • lechugaAmir
                                  • Aug 2016
                                  • 19
                                  • Mexico
                                  hello friend I have bios can I remove password?
                                  HP Stream - 11-ah117wm
                                  • lechugaAmir
                                    • Aug 2016
                                    • 19
                                    • Mexico
                                    HP Stream 11-ah117wm remove password
                                    GRACIAS
                                    Last edited by SMDFlea; 08-22-2022, 01:48 AM. Reason: bios removed,posted once already......
                                    • Mazorca
                                      • Jan 2017
                                      • 463
                                      Re: HP Stream 11-ah117wm remove password
                                      First, read this: https://www.badcaps.net/forum/showthread.php?t=103570, you have two posts.
                                      Next, if you get the i XXXXXXXX digit challange code, read and unlock it yourself:
                                      https://www.badcaps.net/forum/showpo...3&postcount=59
                                      • lechugaAmir
                                        • Aug 2016
                                        • 19
                                        • Mexico
                                        thank you
                                        • DiddiAb
                                          BIOS Backup / extract 16MB .bin - Lenovo ThinkBook 13s G3 ACN - 20YA0005GE
                                          by DiddiAb
                                          Recently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
                                          I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...
                                          03-11-2023, 03:15 AM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          !!! MY RAZER BLADE...
                                          11-24-2025, 05:52 PM
                                        • Chris_stand
                                          Clevo PD50PNN won't boot after BIOS Backup
                                          by Chris_stand
                                          i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
                                          At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
                                          Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
                                          But the...
                                          04-28-2023, 03:08 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
