Asus x441UV rev 2.1 bios need to fix
  • than_22
    • Sep 2017
    • 53
    • philippines
    #41
    Re: Asus x441UV rev 2.1 bios need to fix
    can someone fix my bin file,,
    laptop cant detect harddrive
    there's no barcode on motherboard
    heres my original dump,,
    thank you in advance
    • hoaca388
      Badcaps
      • Jan 2022
      • 12339
      #42
      • James Mi
        • Aug 2020
        • 30
        • Ecuador
        #43
        Originally posted by peste
        try..
        Thanks colleague, it helped me, but a query, how does the bios work when it comes out as extracted in the analyzer and not a stock one?
        • James Mi
          • Aug 2020
          • 30
          • Ecuador
          #44
          What would be the recommendation, of the bios that works to make this a clean me or not?
          • James Mi
            • Aug 2020
            • 30
            • Ecuador
            #45
            X441UV Bios Problem
            Colleagues I have an ASUS X441UV board but it turns out that I put clean bios working on another computer and on my board it doesn't work even cleaning the ME region and nothing but, I found a bios of an X441URK and with that bios it does give me an image but it takes time to give image ? What will be the problem? One detail is that I have the ram that is soldered on just that plate disabled.
            There is a theme of a plate just like that, I took out the bios that I have tried and the bios that gives me an image but it takes seconds to give the image
            • hoaca388
              Badcaps
              • Jan 2022
              • 12339
              #46
              Re: X441UV Bios Problem
              Clear ME region.
                • 21968
                If there is a long white barcode sticker on top of the soldered ram post a picture of it
                • James Mi
                  • Aug 2020
                  • 30
                  • Ecuador
                  #48
                  It seems that they do not have because I just checked on the internet and it is a label just above the soldered ram, and indeed they do not have,
                  Now I tell you a little about the process,
                  disable the soldered ram leaving it as the attached file, all ok, then I wanted to update the bios, it restarted and did not give an image but the consumption is the same as when it is giving an image, then I found the X441URK bios and it gave an image
                  I attach my bios in case it helps
                  • James Mi
                    • Aug 2020
                    • 30
                    • Ecuador
                    #49
                    I can see that my integrated graphics card is a 920MX while when programming the X441URK bios I get that the graphics card is a 930MX I would think that's where the fault comes from
                    • cokan kepo
                      • Jul 2021
                      • 54
                      • Indonesia
                      #50
                      try..
                      it works....thanks bro
                      • singko
                        • Oct 2019
                        • 26
                        • philippines
                        #51
                        Asus x441uv rev 2.1 plzz build
                        Plzz build no display i try other bios but it takes time to display tnxx..
                        • lapfix
                          • Mar 2020
                          • 2765
                          • my workshop
                          #52
                          Re: Asus x441uv rev 2.1 plzz build
                          Try
                          • hunglxag1979
                            • Mar 2020
                            • 3
                            • Vietnam
                            #53
                            try..
                            • pengamat_hebat
                              • Sep 2020
                              • 14
                              • Indonesia
                              #54
                              Hi, I have asus x441uv rev 2.1, no display, fan is spinning, and battery led blink 2 times (white).
                              Specs
                              intel core i3-6006U
                              no discrete graphic
                              I would be very grateful if anyone could help.🙏
                              • peste
                                • Dec 2016
                                • 13653
                                • ROMANIA
                                #55
                                Specs
                                intel core i3-6006U
                                no discrete graphic
                                try..
                                • pengamat_hebat
                                  • Sep 2020
                                  • 14
                                  • Indonesia
                                  #56
                                  try..
                                  Hi peste, thanks for your help. Unfornatunately, It still don't work. I try your "clean me.rar" on page 1, It can boot normally and access bios menu (it's much more modern compared to my previous bios), but I have to wait about 40 seconds or more before the display comes.
                                  any ideas ?
                                  • hardware1
                                    • Sep 2021
                                    • 2948
                                    • N/A
                                    #57
                                    any ideas ?
                                    Try this older version.
                                    Model Number: X441UA-WX321T.
                                    Serial Number: J4N0CV00225714D.
                                    all donations are welcome,
                                    • pengamat_hebat
                                      • Sep 2020
                                      • 14
                                      • Indonesia
                                      #58
                                      many thanks hardware1, but now it become no display, even after reflash bios with peste "clear me" on page 1. Do I need to flash the EC as well ?
                                      please help anyone
                                      My bios and EC dump
                                      • hardware1
                                        • Sep 2021
                                        • 2948
                                        • N/A
                                        #59
                                        please help anyone
                                        My bios and EC dump
                                        So the device was working before but now it's not?
                                        Anyway, here are your files, the EC is extracted from the Main Bios.
                                        You EC Dump file is messy, it doesn't have the correct data.
                                        • pengamat_hebat
                                          • Sep 2020
                                          • 14
                                          • Indonesia
                                          #60
                                          Thank you so much all, especially hardware1 and peste. I managed to fix it by flashing the EC with the file I found on Google, and then reflashing the main BIOS with the latest file given by Peste. I haven't had the chance to try the file you provided yet. This is the EC bin file I used to flash the EC. Thanks anyway Hardware1. 🙏
                                          • to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                            by to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                            I have opened the laptop and identified the main BIOS chip...
                                            10-24-2025, 01:35 AM
                                          • Sebastian Codrean
                                            BIOS file for ASUS F542UN laptop
                                            by Sebastian Codrean
                                            Hello to all of you! I need help with a BIOS file.
                                            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                            02-20-2025, 10:25 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • caglarec2268
                                            Asus X515EA Bios File Please
                                            by caglarec2268
                                            merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                                            Now "please follow the steps below to recover your bios" text remains on the screen
                                            I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                                            laptop model x515ea-bq945w
                                            s/n: R4N0CV02K527148
                                            CN:HWFB
                                            Board model; ASUS X415EA R7.0
                                            bios chip: GD25Q128...
                                            11-27-2024, 03:51 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
