Dell Latitude 7400 Bios Password
  • rddube
    Aspiring Expert
    • Jun 2013
    • 950
    Originally posted by LBTT1121
    try and feedback
    Worked perfectly! Thank you LBTT1121, you rock! Could you explain quickly how it's done, I noticed you changed some areas of the bios with just a few characters ? Thanks again!
    • zeesh17
      • Aug 2025
      • pakistan
      #702
      Kind of new in this area. I want to ask if there is any way to reset bios password without windows or any other operating system? st: H48BK13
      • DAVIDREYEST
        • Sep 2025
        • 5
        • México
        #703
        can someone help me with a dump for EC W25Q80BV fot a dell latitude 7400 ?
          • 21606
          It`s not the EC. Would it be UT6 ,the PD firmware ? https://dl.dell.com/manuals/all-prod...uide_en-us.pdf
          • DAVIDREYEST
            • Sep 2025
            • 5
            • México
            #705
            Thanks , you're right, I SEE ut6 is somenthing for type c, so no major problem, what i need is a bios dump, i programmed it with the one from dell support i didnt know it would brick, now device wont power on.
            I wanted to remove password
              • 21606
              Which chip did you program. Didn`t you make a backup first ?
              • DAVIDREYEST
                • Sep 2025
                • 5
                • México
                #707
                No I didnt make backup, finally i was able to make it work I downloaded a dump from this site and flashed it, computer is working now
                thanks for your help
                it was my first bios reprogramming
                • berrylinx
                  Dell Latitude 7400 2-in-1 bios with absolute persistence lock
                  by berrylinx
                  Dell Latitude 7400 2-in-1 bios with absolute persistence lock, Service Tag: HRPJN53
                  Can someone please assist with this please. I've provided two dump files using Xgeco T48, one is the read and default saved and other is the Flash saved option, they're labeled according.
                  Thank You....
                  09-15-2025, 03:02 PM
                • gizaha
                  by gizaha
                  02-13-2024, 07:18 AM
                • jhanra
                  by jhanra
                  11-02-2024, 04:19 AM
                • anlsmith
                  Dell Latitude 5430 Bios Password
                  by anlsmith
                  I am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it...
                  08-31-2024, 08:46 PM
                • YOUCEF4787
                  Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                  by YOUCEF4787
                  I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                  Initial Problem:
                  The laptop was completely dead, no signs of life, no power LED.
                  Action Taken:
                  I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                  Current Situation & The Main Issue:
                  The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                  09-21-2025, 12:19 PM
