Dell Latitude 7400 Bios Password
Greetings, I also need a bios unlock, can someone help me and thank you very much in advance
Dell Latitude 7400
ST:7WLW5Y2
EX:17209166618
Attached FilesComment
https://www.badcaps.net/donateComment
Unlocked or https://bios-pw.org/Comment
Can someone please remove the password?
Dell Latitude 7400
Express service code 1845491311
Service TAG 8GQ2833 # 8FC8
Thanks!Attached FilesComment
Thank you guys, i hope this file is correct!
Can you explain to me how I can tell if the file is correct?Attached FilesComment
1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing modeAttached FilesComment
your file is still corrupt. but you can use this its clean and unlocked. make sure to verify after flashing. if it doesn't boot you have problem with your solder or programmer.
you got any advice for me?Comment
Hello, would you take a look at this one for me?
Dell Latitude 7400
Service Tag: HGM5633
Express Service Code: 38009951247
Problem: Password
Thank you!Attached FilesComment
TryAttached Files↵
Attached Files↵
I bout a latitude 7400 from Facebook marketplace. It worked when I bought it but after formatting the hd and trying to reinstall windows it's asking for a bios password. The person I bought it from is no longer showing up in search so I can't ask them what it is. #252TN13-E7A8 Can anyone help me?Comment
hello
pleas unlock
dell 7400 SN 5GJHL33
thanksAttached FilesComment
by berrylinxDell Latitude 7400 2-in-1 bios with absolute persistence lock, Service Tag: HRPJN53
Can someone please assist with this please. I've provided two dump files using Xgeco T48, one is the read and default saved and other is the Flash saved option, they're labeled according.
Thank You....-
Channel: BIOS Requests ONLY!
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by anlsmithI am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it...
by YOUCEF4787Hello everyone,
I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
Initial Problem:
The laptop was completely dead, no signs of life, no power LED.
Action Taken:
I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
Current Situation & The Main Issue:
The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly.... - Loading...
