Dell Latitude 7400 Bios Password
  • rddube
    Aspiring Expert
    • Jun 2013
    • 950
    Originally posted by LBTT1121
    try and feedback
    Worked perfectly! Thank you LBTT1121, you rock! Could you explain quickly how it's done, I noticed you changed some areas of the bios with just a few characters ? Thanks again!
    • zeesh17
      • Aug 2025
      • pakistan
      #702
      Kind of new in this area. I want to ask if there is any way to reset bios password without windows or any other operating system? st: H48BK13
      • DAVIDREYEST
        • Sep 2025
        • 5
        • Mรฉxico
        #703
        can someone help me with a dump for EC W25Q80BV fot a dell latitude 7400 ?
          • 21679
          It`s not the EC. Would it be UT6 ,the PD firmware ? https://dl.dell.com/manuals/all-prod...uide_en-us.pdf
          • DAVIDREYEST
            • Sep 2025
            • 5
            • Mรฉxico
            #705
            Thanks , you're right, I SEE ut6 is somenthing for type c, so no major problem, what i need is a bios dump, i programmed it with the one from dell support i didnt know it would brick, now device wont power on.
            I wanted to remove password
              • 21679
              Which chip did you program. Didn`t you make a backup first ?
              • DAVIDREYEST
                • Sep 2025
                • 5
                • Mรฉxico
                #707
                No I didnt make backup, finally i was able to make it work I downloaded a dump from this site and flashed it, computer is working now
                thanks for your help
                it was my first bios reprogramming
                • DNAGSM
                  • Jun 2023
                  • 16
                  • Algeria
                  #708
                  i need remove Password Bios
                  Model Dell Latitude 7400
                  System Number JJ8VM13-8FC8
                  Board ID EDC40 LA-G871P REV:1.0 (A00) 2019-02-22
                  • LBTT1121
                    • Nov 2024
                    • 735
                    • Viแป‡t Nam
                    #709
                    try and feedback
                    • Markus1741
                      • Sep 2020
                      • 923
                      • N/A
                      #710
                      Unlocked ....
                      • DNAGSM
                        • Jun 2023
                        • 16
                        • Algeria
                        #711
                        Unlocked ....
                        Not Working , The processor fan runs at full speed without starting
                        • DNAGSM
                          • Jun 2023
                          • 16
                          • Algeria
                          #712
                          try and feedback
                          Not Working , No Power ON
                          • miyagik
                            • Jun 2018
                            • 32
                            • Mexico
                            #713
                            Try
                            • berrylinx
                              Dell Latitude 7400 2-in-1 bios with absolute persistence lock
                              by berrylinx
                              Dell Latitude 7400 2-in-1 bios with absolute persistence lock, Service Tag: HRPJN53
                              Can someone please assist with this please. I've provided two dump files using Xgeco T48, one is the read and default saved and other is the Flash saved option, they're labeled according.
                              Thank You....
                              09-15-2025, 03:02 PM
                            • gizaha
                              by gizaha
                              02-13-2024, 07:18 AM
                            • jhanra
                              by jhanra
                              in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, ๐Ÿ˜…๐Ÿ˜…๐Ÿ˜…...
                              11-02-2024, 04:19 AM
                            • anlsmith
                              Dell Latitude 5430 Bios Password
                              by anlsmith
                              I am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it...
                              08-31-2024, 08:46 PM
                            • YOUCEF4787
                              Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                              by YOUCEF4787
                              I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                              Initial Problem:
                              The laptop was completely dead, no signs of life, no power LED.
                              Action Taken:
                              I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                              Current Situation & The Main Issue:
                              The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                              09-21-2025, 12:19 PM
