Bl51 la-d711p rev 3.0 İo /rom workİng please
Tags: None
Re: Bl51 la-d711p rev 3.0 İo /rom
Use the search: "la-d711p"
https://www.badcaps.net/forum/showthread.php?t=66687Last edited by SMDFlea; 01-21-2020, 04:59 AM. -
thank you dump workingElectronicmanComment
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by Csfrommhi , i am looking for a working bios dump.
HP bricked the bios with the updates.
so i need the 1st version of the bios dump if its possible.
thank you...-
Channel: BIOS Requests ONLY!
Hello guys, can someone help me with an eMMC dump for a Sony KDL55W-955B TV, I tried to read the original memory with the RT809H but it shows me that it only has 1888MB even though it should have around 3.8GB. On a new memory it shows me 3776MB. From what I found on the Sony page, the following models could also be compatible:
KDL-65W955B, KDL-55W955B, KDL-60W855B, KDL-50W805B, KDL-42W705B, KDL-32W705B, KDL-48W605B, KDL-40W605B, KDL-60W605B, KDL-55W805B, KDL-42W805B, KDL-48W585B, KDL-32W706B, KDL-42W706B, KDL-42W815B, KDL-42W817B, KDL-50W815B, KDL-55W815B, KDL-42W828B, KDL-42W829B,... -
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
- Loading...
