hp 255 g5 bios
  • alibisma
    • Oct 2014
    • 37
    • Saudia
    hp 255 g5 bios
    hp 255 g5 bdl51 la-d711p rev 3.0 need bios can anyone help me
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: hp 255 g5 bios
    Either post your old bios or tell us the BID number of your bios.
    • dspok
      • Jan 2014
      • 554
      • Nepal
      Re: hp 255 g5 bios
      attached is original bios from HP website.
      One of the bin inside the archive will work.
      good luck.
      • alibisma
        • Oct 2014
        • 37
        • Saudia
        Re: hp 255 g5 bios
        thanks bro its woring 100%
        • Gobbla
          • Mar 2015
          • 27
          • United Kingdom
          Re: hp 255 g5 bios
          hi
          cant open that rar file ???
          but I found another one
          enjoy
          • Ghost18_07
            Zakaria
            • Mar 2018
            • 87
            • Algeria
            Re: hp 255 g5 bios
            Thanks guys
            • keegun
              • Feb 2019
              • 1
              • united kingdom
              Re: hp 255 g5 bios
              thanks
              • sel3370
                • Aug 2017
                • 18
                • turkey
                Re: hp 255 g5 bios
                Thanks Tested % 100 ok
                • cristiannec
                  • Oct 2014
                  • 51
                  • Italia
                  Re: hp 255 g5 bios
                  works 100% thanks.
                  • mcoytzhi27
                    Mr
                    • Nov 2015
                    • 43
                    • philippines
                    Re: hp 255 g5 bios
                    101 working file.. Thumps up!!!!!
                    • garysss
                      • Mar 2020
                      • 1
                      • Uruguay
                      Re: hp 255 g5 bios
                      the extension for this file is .rom, no compatibility, i need . bin file.
                      • piernov
                        • Jan 2016
                        • 4439
                        • France
                        Re: hp 255 g5 bios
                        … Rename it?
                        • supun1992
                          • Jun 2017
                          • 13
                          • Sri lanka
                          Re: hp 255 g5 bios
                          la-d711p rev 1.0 plz?
                            • 22275
                            Re: hp 255 g5 bios
                            Post #3 and 5. The revision # makes no difference,same bios.Check your bid number, look on youtube videos how to check.
                            • Pascal Komlassan
                              • Jan 2017
                              • 808
                              • TOGO
                              Re: hp 255 g5 bios
                              Originally posted by dspok
                              attached is original bios from hp website.
                              Good luck.
                              thank's
                              • snakepit7
                                • Dec 2015
                                • 29
                                • mexico
                                Re: hp 255 g5 bios
                                Thank's!!!
                                • nishatkhan.pk
                                  • Sep 2020
                                  • 1
                                  • Pakistan
                                  Re: hp 255 g5 bios
                                  Orignal bios
                                  • platinumsteel
                                    • May 2019
                                    • 238
                                    • Trinidad&Tobago
                                    Re: hp 255 g5 bios
                                    good luck.
                                    Thanks a lot for this . 081F5.bin worked for me. In case any of you guys want to know which one will work with your board.Take an original dump and do a search for 081F and you will see which one of the four u need to flash for you board.In my case my original dump had 081F5 so i picked that one out of the 4 from dspok . Hope this helps someone.
                                    • lordgeny
                                      • Apr 2016
                                      • 227
                                      • Italia
                                      Re: hp 255 g5 bios
                                      i fixed a dead hp with this bin, but now at boot it say manufacturer programming mode is unlocked, how to remove it ?
                                      thats my dump , i flashed 081f5
                                      • peste
                                        • Dec 2016
                                        • 13920
                                        • ROMANIA
                                        Re: hp 255 g5 bios
                                        https://www.youtube.com/watch?v=9T57ktw8n3Y
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          [Problem/ Request] Bricked TongFang GK7MRFR BIOS
                                          by cr4zychriss
                                          I am requesting urgent assistance to unbrick my laptop, a rebranded TongFang GK7MRFR chassis. The laptop is completely dead following a faulty in-OS EC flash attempt.
                                          I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details
                                          • Barebone / Chassis: TongFang GK7MRFR
                                          • MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product Name: Razer Blade 15 (2022)
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          BIOS Versions I work with: 2.02 & 2.06
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                                          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                                          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                                          !!! MY RAZER BLADE...
                                          11-24-2025, 05:52 PM
