bios dump search HP 17-cp0579ng
  • Csfromm
    • Oct 2023
    • 8
    • Deutschland
    hi , i am looking for a working bios dump.
    HP bricked the bios with the updates.
    so i need the 1st version of the bios dump if its possible.
    thank you
    • 21936
    thank you
    Post your corrupd backup, and the required laptop serial number - https://www.badcaps.net/forum/troubl...before-posting
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • studdy05
      Bricked HP Probook 450 G7 Bios questions
      by studdy05
      Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
      Ive got...
      07-08-2025, 09:24 PM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
