HP650 ProBook G1 Product Information Not Valid
  • dr.tubes
    • Jan 2020
    • 21
    • Serbia
    I have a HP ProBook 650 G1 - when I start the laptop I am getting a message Product Information Not Valid. I know I am supposed to write the info manually, but I am not sure how. Which tool should I use to write the product info manually? I tried using HDMI tool and DR. Bios, but it's not working. MB manufacturer is Inventec.
    Waiting for helpful advice...
    MPM is unlocked.
  • peste
    • Dec 2016
    • 13756
    • ROMANIA
    Re: HP650 ProBook G1 Product Information Not Valid
    try...
    https://www.youtube.com/watch?v=rP3A3HWM_-Q
    • dr.tubes
      • Jan 2020
      • 21
      • Serbia
      I tried doing everything as described in the link, but when I write in all the numbers and save after the setconfig, I restart the laptop and nothing is saved. I am not sure if my MPM is locked or not. It says *Lock.
      At the beginning of a video at the link, there is a message that MPM is unlocked. I am not getting the message.
      How can I unlock it? Using a smc.bin file, and where can I find it?
      Should I use WNDMIFIT after that?
      UUID option in BIOS says FFFFFFF.... Is it supposed to be like that?
      What should I do first and how can I solve this problem?
      Also, I can't find FEATURE BYTE number of my laptop. I have been using the number from another HP, same model.
      Thanks.
      • imranromi
        • Jan 2015
        • 1290
        • Pakistan
        Thanks.
        Post here bios file i will help.
        • dr.tubes
          • Jan 2020
          • 21
          • Serbia
          How can I post bios file? Which file?
          • dr.tubes
            • Jan 2020
            • 21
            • Serbia
            Do you mean BIOS Configuration Utility config.txt file ?
            • imranromi
              • Jan 2015
              • 1290
              • Pakistan
              Bios file you need bios programmer read chip and post here.Otherwise no have option solve your problem.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3630
                • slovakia
                use some software that can extract bios dump
                try from this post
                https://www.badcaps.net/forum/showthread.php?t=54885
                but u dont need it
                u can use NBDMIFit or check if your bios contains tool for change this info.
                All info u can find onback side of chasis
                • dr.tubes
                  • Jan 2020
                  • 21
                  • Serbia
                  I tried with universal bios toolkit 2.0 , but it cant identify bios.
                  I tried with NBDMIFit but it doesn't work.
                  • dr.tubes
                    • Jan 2020
                    • 21
                    • Serbia
                    Do I have to remove the bios chip from the MB to read bios?
                    • imranromi
                      • Jan 2015
                      • 1290
                      • Pakistan
                      Correct.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3630
                        • slovakia
                        not with clip
                        • dr.tubes
                          • Jan 2020
                          • 21
                          • Serbia
                          I have ordered an sp eeprom programmer ch341a. I have read that I have to modify the pcb to 3.3 volts.
                          I have found the .bin bios files for my HP laptop.
                          The files are rar, and when I extract them I am getting a power.iso image file.
                          I have tried to extract it in Power Iso, but I can't.
                          How can I extract the bios files from power.iso image file to use the with eeprom programmer?
                          I am the beginner with this kind of problems, I could really use some help.
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3630
                            • slovakia
                            Did u try use more NBdmifit versions? different versions is for different bios
                            did u try search in bios for page where u can change dmi info?
                            just flash that iso, but u want to read your bios. flashing that iso give u exact same result as u have now
                            CH341 use 3,3V so no other adapter needed for 3,3V bios ic
                            u need adapter if u want to flash 1,8V bios ic
                            • dr.tubes
                              • Jan 2020
                              • 21
                              • Serbia
                              I have tried different versions of NBdmifit for my bios, but without success.
                              I understand that .bin iso file is a bios - I opened it in Hex Editor.
                              I saw how to modify ch341a at this link
                              https://www.onetransistor.eu/2017/08...schematic.html.
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3630
                                • slovakia
                                read his page again carefully
                                • dr.tubes
                                  • Jan 2020
                                  • 21
                                  • Serbia
                                  This is my old bios file. I removed the BIOS form the MB and read the bios file.
                                  My bios chip number is 25Q128FVSO, but my USB Eprom CH341A recognizes it as 25Q128WBD. I have no other options to choose my file, but I managed to work with it without problems.
                                  I tried to read the new BIOS file to my laptop, but when I turn on the laptop I am getting the same error message.
                                  You said that you can help me. Thanks again.
                                  • dr.tubes
                                    • Jan 2020
                                    • 21
                                    • Serbia
                                    • imranromi
                                      • Jan 2015
                                      • 1290
                                      • Pakistan
                                      Try this and post results
                                      • dr.tubes
                                        • Jan 2020
                                        • 21
                                        • Serbia
                                        Thank you so much! Everything works!
                                        I read the new BIOS, soldered the chip to MB and it's great.
                                        • ahmedtou
                                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                          by ahmedtou
                                          help me please
                                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                          I will share all the details with you, including the disc information.
                                          Code:
                                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                          Current Profile: BD-R
                                          Disc Information:
                                          Status: Empty
                                          State of Last Session: Empty
                                          Erasable: No
                                          Free Sectors: 12,219,392
                                          Free Space: 25,025,314,816 bytes
                                          Free Time: 2715:27:17 (MM:SS:FF)
                                          Next
                                          08-27-2025, 08:49 AM
                                        • pieciak
                                          HP 820 G1 - Product Information not Valid
                                          by pieciak
                                          Hello, HP 820 G1 laptop - "Product Information not Valid" error when turned on, you have to press enter and stop to understand the HP BIOS Configuration Unit according to the guide
                                          on YouTube: https://tiny.pl/dq69t
                                          However, at the very beginning I get this error:
                                          <ERROR msg="Unable to process command. Password is set, but no password file is provided" /> <ERROR msg="BCU return value" real="10" translated="10" />
                                          Can anyone help me so that I don't have to press enter every time? Help...
                                          02-22-2024, 08:57 AM
                                        • crash_10uk
                                          HP Notebook - 15-Ac107na Product Informaion Not Valid
                                          by crash_10uk
                                          Hi all hope you can help.
                                          A customer asked me to take a look at her Notebook. Upon booting the notebook and message appears.
                                          Product Information to valid
                                          The Following product information programmed into the system board is missing or invalid
                                          System Board (00A) - System Board CT Number
                                          The Notebook is a HP Notebook - 15-Ac107na
                                          Does anyone have the proper DMI tools for this, i have tried a few and all i get is "accessed denied" when trying to set new config
                                          I would be greatful for any help
                                          03-25-2023, 05:49 AM
                                          HP ProBook ProBook 450 G3 Notebook PC (ENERGY STAR) Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook ProBook 450 G3 Notebook PC (ENERGY STAR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook 450 G3 Notebook PC (ENERGY STAR) boardview and ProBook 450 G3 Notebook PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 06:42 AM
                                          HP ProBook ProBook 470 G5 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook ProBook 470 G5 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook 470 G5 Notebook PC boardview and ProBook 470 G5 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 06:40 AM
