bios chips
  • el panke
    • May 2019
    • 78
    • argentina
    bios chips
    hi guys im trying to fix this laptop (compaq 21nr) that uses w25q32fvsig bios chip, somehow cant be erased
    so i have laying arround an mx25l3206e chip
    the question is, can be replaced the w25q with the mx25?
  • khelane
    • Apr 2015
    • 172
    • xxxx
    Re: bios chips
    yes
    you can replace 25q32bv
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Re: bios chips
      It depends on the supported list of bios chip in your bios. If MX25L3206E is listed, then only it will work. If you dont know how to check that, then post your original bios backup here. Someone will figure it out for you.
      • el panke
        • May 2019
        • 78
        • argentina
        Re: bios chips
        i dont know how to check that
          • 21692
          Re: bios chips
          Open the bios with UEFITool,click on the small triangle next to Intel image,then Descriptor region. In the right hand column it will say: Flash chips in VSCC table: .Search on google for Atmel 1F4700,Winbond EF4016,Amic 373016,Macronix C22016 to find the full bios part number.Another way to find the chips is to open the bios with Intel flash image toolkit and look at the vscc tables.
          https://github.com/LongSoft/UEFITool..._A55_win32.zip
          • el panke
            • May 2019
            • 78
            • argentina
            Re: bios chips
            well seems like is not
            thanx alot smdflea
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Re: bios chips
              thanx alot smdflea
              See you perhaps learnt a lesson. You simply cant ignore the basic things and keep on changing components.
              • Techtiger
                • Oct 2014
                • 1602
                • france
                Re: bios chips
                Keep up the good work
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                  by Vesko356
                  08-11-2023, 03:27 AM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • lucaszmn
                  by lucaszmn
                  Problem:
                  Initial Findings:
                  • I concluded that the
                  08-12-2025, 03:01 PM
