IIBTDL-Borg 13057-1M bios
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Hi do you have this bios file of this board it just boot with blank display
    • 22084
    Re: IIBTDL-Borg 13057-1M bios
    Post your bios backup . It could be a bad cap though,so desolder and check esr or just replace:
    https://www.badcaps.net/forum/showthread.php?t=64073
    http://semige3k.blogspot.com/2017/08...rg-iibtdl.html
    • kenkaniff
      HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
      by kenkaniff
      Product Name: HP Pro x360 Fortis 11-inch G9
      System BIOS: U94 Ver.01.08.00 10/06/2023
      Serial Number: 5CG31946F5
      SKU Number: 85W05EC#AK8
      Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
      This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
      I needed to remove bios password...
      10-01-2025, 04:32 AM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • Neddsme
      Bios partially corrupted somehow and now warm boot doesn't work which is critical
      by Neddsme
      Hie.
      I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
      Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
      I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
      I managed to run Windows troubleshooting and...
      02-04-2022, 05:57 AM
    • Max029
      Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
      by Max029
      I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
      I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
      TY,
      08-18-2024, 08:28 PM
    • 0xx
      2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
      by 0xx
      Hi folks,
      My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
      What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
      I assumed that Windows Update was interrupted due to closing...
      09-14-2025, 03:46 PM
