HP Elite x2 1012 G2 fix BIOS password
  • darckreign1984
    • 260
    • Romania
    #41
    hp elite x2 1012 g2
    the tablet have password on bios.
    thanks in advance again
    Picture from inside
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      #42
      Re: hp elite x2 1012 g2
      BIOS guides, methods, resources and tools
      Password removal by laptop brand
      Become a Badcaps supporter
      Thanks to all supporters.​
      • darckreign1984
        • 260
        • Romania
        #43
        Re: HP Elite x2 1012 G2 fix BIOS password
        Solved.
        thanks
        • virusjez
          • Jun 2017
          • 34
          • Philippines
          #44
          please help me unlock
          • lapfix
            • Mar 2020
            • 2756
            • my workshop
            #45
            Try and see instructions
            • virusjez
              • Jun 2017
              • 34
              • Philippines
              #46
              Thank you very much sir..it works.. GodBless you
              • 19dt
                • Jun 2023
                • 12
                • Spain
                #47
                Problem deleting bios password on hp elite x2 1012 g2. HELP!!!
                Hello everyone, I am new to the world of electronics.
                I bought a laptop hp elite x2 1012 g2 with winbond 25Q128JVPQ bios chip with password in bios that I want to delete.
                I have bought a CH341A programmer which I am going to modify to 3.3V.
                The problem I have is that I have not desoldered the chip and with the tweezers does not read well the chip and returns me empty FF all fields.
                The software I am using is asprogramer 2.0.0a14.
                I need to be able to read the chip file please!!!!
                  • 21692
                  Re: Problem deleting bios password on hp elite x2 1012 g2. HELP!!!
                  The chip type is WSON8 ,your clip is for SOP8 chips.You will not make good contact with the clip,you will damage the chip.
                  • 19dt
                    • Jun 2023
                    • 12
                    • Spain
                    #49
                    The only way is to desolder the chip and in which clip do you advise me to put it?
                    • 19dt
                      • Jun 2023
                      • 12
                      • Spain
                      #50
                      This is the bin file of my bios, I need to remove the password please!!!! Can someone help me? thank you very much
                      • Vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #51
                        It's not a good read, try again and use verification. Take two or three dumps from the chip and compare them.
                        • 19dt
                          • Jun 2023
                          • 12
                          • Spain
                          #52
                          now I have a problem, I accidentally deleted the chip after the wrong reading as you tell me.
                          What can I do now?
                          • lapfix
                            • Mar 2020
                            • 2756
                            • my workshop
                            #53
                            What can I do now?
                            Try another clean me bios and see if it work.
                            Or ,write your serial number and somone will built a new bios
                            I wouldn't advise you to use the clip, most of the time it gives errors.. if you don't have a chip adapter stick wires between the chip and the programmer... don't forget to make a backup copy of the chip before writing..
                            • 19dt
                              • Jun 2023
                              • 12
                              • Spain
                              #54
                              the serial number of the laptop is 5CG8315GTD, I also attach an image where you can see the characteristics.
                              • lapfix
                                • Mar 2020
                                • 2756
                                • my workshop
                                #55
                                Try and give feedback
                                • 19dt
                                  • Jun 2023
                                  • 12
                                  • Spain
                                  #56
                                  Thank you very much, I will try it at the weekend.
                                  • 19dt
                                    • Jun 2023
                                    • 12
                                    • Spain
                                    #57
                                    hello lapfix.
                                    I tried the bin file that you sent me but now the laptop doesn't do anything, it only lights up the led with yellow light, orange and white light blinking.
                                    Is it possible that the file is invalid? or that the chip has been damaged?
                                    thank you
                                    • lapfix
                                      • Mar 2020
                                      • 2756
                                      • my workshop
                                      #58
                                      hello lapfix.
                                      thank you
                                      I just built a new bios with your serial and clean me.
                                      try another file with same model...when you have a result just ask to clean me
                                      • 19dt
                                        • Jun 2023
                                        • 12
                                        • Spain
                                        #59
                                        what do you mean by "try another file with the same model...when you get a result just ask me to clean it up"?
                                        • 19dt
                                          • Jun 2023
                                          • 12
                                          • Spain
                                          #60
                                          good afternoon everyone, when desoldering the chip I have noticed a "bubble" that has come out on the board, can anyone tell me what it is?
                                          Thank you very much
                                            HP Elite x2 1012 G2 + Elite Presenter Mouse + Essential Top Load Case Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                                            This specification for the HP Elite x2 1012 G2 + Elite Presenter Mouse + Essential Top Load Case Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1012 G2 + Elite Presenter Mouse + Essential Top Load Case boardview and 1012 G2 + Elite Presenter Mouse + Essential Top Load Case schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                            09-06-2024, 08:20 AM
                                            HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                                            This specification for the HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G2 Tablet (ENERGY STAR) boardview and Elite x2 1012 G2 Tablet (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 07:10 AM
                                            HP Elite x2 Elite x2 1012 G2 Tablet Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                                            This specification for the HP Elite x2 Elite x2 1012 G2 Tablet Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G2 Tablet boardview and Elite x2 1012 G2 Tablet schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            09-06-2024, 06:30 AM
                                            09-06-2024, 06:10 AM
