HP Elite x2 1012 G2 fix BIOS password
  • peste
    • 13917
    • ROMANIA
    Re: HP Elite x2 1012 G2 fix BIOS password
    Originally posted by B0SSRiC3
    Could you please help me with the flash process.
    I have exactly the same device wit an W25Q128JVPQ Chip.
    I can read, erase, blank check but not write successfuly.
    I am using the Ch341A Programmer with the Chip disoldered from mainboard and connected to the programmer with jumper wires.
    I've teste NeoProgrammer aswell. when i auto programm the chip, the process errors immediately. When i write only it finishes but the verifying is faulty.
    Thank you so much for your help
    try this..
    https://www.badcaps.net/forum/showpo...6&postcount=10
    • B0SSRiC3
      • Sep 2021
      Originally posted by peste
      Thank you peste,
      the flashing process works but the verifying shows different values.
      Does it really work with an standard CH341A Programmer or do i need a better one, like the TL866II?
        • 22275
        Thank you peste,
        Try shortening the jumper wires as much as possible. Have you modified the programmer to run spi at 3.3V , search on google for "ch341a 3.3v mod" theres lots of guides and youtube videos, it will make it more stable.
        • B0SSRiC3
          • Sep 2021
          Thank you,
          i`m trying it rn. Hope that my dumps are good.
          I've read that i need a better programmer for the W25Q128JVPQ.
          • B0SSRiC3
            • Sep 2021
            I don't know if it was the shortening of the jumper wires or the 3.3V Mod of the Programmer. I did both and the Tablet is working again.
            Thank you both very much.
            • JPToadstool
              • May 2020
              • 19
              #26
              HP Elite X2 1012 G2 BIOS PW removal
              Can someone kindly remove the password from the attached BIOS bin please?
              Thank you in advance!
              • ymifdal
                • Jan 2022
                • 120
                • Morocco
                #27
                Re: HP Elite X2 1012 G2 BIOS PW removal
                Hello you could just use RCUnlocker it's easy
                but here you go, after entering BIOS go to security tab and reset security to default settings
                • JPToadstool
                  • May 2020
                  • 19
                  #28
                  Thanks, re-soldered the BIOS chip but it is currently flashing yellow and white alternating. Any idea what's causing this?
                  • peste
                    • 13917
                    • ROMANIA
                    #29
                    write back the original bios and see if it starts again..
                    • gimikgo
                      • Oct 2022
                      • 8
                      • malaysia
                      #30
                      i faced a same issue, after flash the bios gen by RCUnlocker, the tablet not longer boot on.
                      write back the original bios, the problem persists.
                      seem like i dump a fail bios, any ways to reverse the problem.
                      • gimikgo
                        • Oct 2022
                        • 8
                        • malaysia
                        #31
                        attached the bin, if anyhing can be done.
                        • peste
                          • 13917
                          • ROMANIA
                          #32
                          be careful when writing and reading..remove the bios chip from the motherboard before reading or writing...do not use the clip, it gives errors if the contact is not firm....which programmer do you use??
                          • gimikgo
                            • Oct 2022
                            • 8
                            • malaysia
                            #33
                            i desoldered from motherboard and use adaptor to read the ic and use the programmer software to verify and not error prompt. The programmer used is ezp 2019.
                            • peste
                              • 13917
                              • ROMANIA
                              #34
                              did you solder the chip to the board well?? maybe you damaged the chip when soldering.. if you used the blower maybe some resistance around the chip jumped.. do you have voltage on the chip?? check the wiring around the chip..
                              • gimikgo
                                • Oct 2022
                                • 8
                                • malaysia
                                #35
                                The ic connection is checked with nearby pad, solder condition should be ok. I double checked the photo capture before reworked, no chips is blow off. The supply to ic 3.3v is able to measure. Planned next week end to confirm the ic still workable or not by connected by to the programmer. If have things that I missed, please let me know. Thanks.
                                • mouad512
                                  • Dec 2021
                                  • casablanca
                                  #36
                                  Re: HP Elite X2 1012 G2 bios password
                                  Originally posted by marcin02152
                                  try
                                  hi can you help me please need to remove password bios for hp elite x2 1012 G2
                                  • gimikgo
                                    • Oct 2022
                                    • 8
                                    • malaysia
                                    #37
                                    after reconnected to the programmer, the IC is still readable, is alive.
                                    I tried one of bin file in this forum, able to bring the device bootable,
                                    but it prompted security device problem.
                                    Which I believe this is the sign my dump file is corrupted.
                                    Now i planned to tried to clean the ME region for my bin file. hopefully, is the me region corrupted cause this issue.
                                    If my step is not right, please let me know. thanks.
                                    • gimikgo
                                      • Oct 2022
                                      • 8
                                      • malaysia
                                      #38
                                      After clean me region and dmi editing, the security device problem massege still shown, in the moment, seem like no usage issue, in the moment cannot think other solution to try.
                                      • peste
                                        • 13917
                                        • ROMANIA
                                        #39
                                        try this....go into bios and restore security settings to defaults and restart laptop
                                        • gimikgo
                                          • Oct 2022
                                          • 8
                                          • malaysia
                                          #40
                                          this steps was performed, but the message don't disappear.
                                            HP Elite x2 1012 G2 + Elite Presenter Mouse + Essential Top Load Case Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                                            This specification for the HP Elite x2 1012 G2 + Elite Presenter Mouse + Essential Top Load Case Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1012 G2 + Elite Presenter Mouse + Essential Top Load Case boardview and 1012 G2 + Elite Presenter Mouse + Essential Top Load Case schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                            09-06-2024, 08:20 AM
                                            HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                                            This specification for the HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G2 Tablet (ENERGY STAR) boardview and Elite x2 1012 G2 Tablet (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 07:10 AM
                                            HP Elite x2 Elite x2 1012 G2 Tablet Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                                            This specification for the HP Elite x2 Elite x2 1012 G2 Tablet Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G2 Tablet boardview and Elite x2 1012 G2 Tablet schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            09-06-2024, 06:30 AM
                                            09-06-2024, 06:10 AM
