hp 840 g6 6050A3022501-MB-A01
Attached FilesComment
SN# 5CG014CJ3G ,i used your bios posted her it's working but just with this picture please help.Comment
https://www.badcaps.net/donateComment
Rremove battery , disconnect even the 3V cell , write my version of BIOS, plug in the charger and go for a walk for 30 minutes, or take a nap. Do not touch any buttons not even the power button ...
If your hardware is OK as you say the laptop must start in MPM mode.Comment
I told you to be patient.
I solve display issue with this dump.thanks for help.Attached FilesComment
hi there to all pro's
hp 840 g6 laptop , or craptop ,, motherboard 6050a3022501
all voltages good except on L66310 which i persume are gor the graphics side ..
i have tried all bios and ec bios on this forum from page 1 to 25 , laptop powers up , you can spot the the lcd goes black as the 3v is ok , but no backlight no graphics or post
laptop runs with power led on and cpu fan spins as it should
all this but still no post ,,
any advise or sugesstions would be appriciated
thanks all
waiting for reply
pls help , from this bios Display is coming very late
Model HP Elitebook 840 G6
S/N :- 5CGO429R97
Need Help for BIOS 1mb HP Elitebook 840 G6 (Crescent-6050A3022501-MB-A01)
MXIC
MX25L800GE2NI (Bios Size 1MB)
This chip already flash by other technician, and we dont have backup file.. anyone have a backup file, please share, thanks before1 PhotoComment
Here you are...
Mine is Winbond 25Q80DVIGAttached FilesComment
update after i flash this file, the laptop still not turn on, i think the problem not from bios file anymore the bios is OK, another suspect is 3.3V ic DC/DC was defect because the output voltage only 2.64V. i will try to replace this IC. Thanks for your help Master
Good Luck!Comment
by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
Channel: BIOS Requests ONLY!
by longmt1990Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
Please help me remove bios password.
Thank you so much-
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
>Read BIOS guides, methods, resources and tools
Ack
>Try the method at BIOS guides, methods, resources and tools before requesting help
Ack
>Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
by justice171Hi BadCaps team,
I’m asking for a bit of community help with a Proline notebook that’s stuck with a Power-ON (BIOS) password. The laptop has very limited info available and I suspect it may be a local (South African) Proline board. Thought I’d check here in case anyone has seen this one before.
What I have:- Model: Proline NoteBook V146GNK
- Board: SU_GN100_MB_V12_20231120A
- Serial: GN10Q12124205W1588
- Notes: 12V main board. Very little documentation available.
What I’d like to request:- Has anyone dealt with this Proline board before or seen matching BIOS/firmware
by fx1982Hi everyone, can someone please help to remove bios Administrator password or decode as I failed miserably... Tried reading the password but it says wrong password. Thank you in advance!
It's a 2024 Asus Zephyrus G16
GU605MV
SN: S2NRCX035924088
CN: AEDW
MFD: 2024-02 36M
BIOS VERSION: 315...-
- Loading...
