hp 840 g6 6050A3022501-MB-A01
Hi Blaze Tech,
Please, only one more help. After I write the 16MB unlock bin file, I need to restore the factory defaults and/or restore security bios defaults after first boot or not?
Tks,
VilmarComment
HP EliteBook 840 G6
SN: 5CG01464XX
with bios Password and DeviceFreeze problem. thanksComment
I tried to find out but couldn't find a solution to the "hp endpoint security controller problem" error. without the original bios,,, I wonder if someone has been able to fix this error without the original bios?Comment
Attached FilesComment
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
use BCU. you can permanently disable Absolute lock in BCU.
here's your DMI:
Serial Number: 5CG01464XX
Product #/SKU: 7UA41UC#UUF
CT Number: PHWGH00WBDKLW4
Description: HP EliteBook 840 G6
BuildID: 19WWCFBT601#SUUF#DUUF
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkjhk8.gnLast edited by rex98; 05-21-2024, 09:50 PM.Comment
This is the bios when I first read it (I saw it had been changed and didn't work)
sn :5CG04240VN
here's your DMI:
Serial Number: 5CG04240VN
Product #/SKU: 7UA64UC#UUF
CT Number: PHWGL00WBEC07B
BuildID: 19WWCFCT601#SUUF#DUUF
Feature Byte: 3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhdUdpdqfPgShKj4jhk8.dt
flash the original EC and this main.
here's your DMI:
Feature Byte: 3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhdUdpdqfPgShKj4jhk8.dtLast edited by trunguntilyou; 05-22-2024, 01:08 AM.Comment
do not touch the EC only flash this main. RC unlocker can only be used in 16mb chips EC. it cannot removed Absolute lock/ Device Freeze.
here's your DMI:
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkjhk8.gnComment
Hi, can you help, no power on ?
HP 840 g6
SN:5CG0091FTR
I've tryed few EC + main from older posts, it's power on ,but with Endpoint problem. Can you fix my files ?Attached FilesComment
Attached Files↵
https://www.badcaps.net/donateComment
by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
Channel: BIOS Requests ONLY!
by longmt1990Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
Please help me remove bios password.
Thank you so much-
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
>Read BIOS guides, methods, resources and tools
Ack
>Try the method at BIOS guides, methods, resources and tools before requesting help
Ack
>Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
by justice171Hi BadCaps team,
I’m asking for a bit of community help with a Proline notebook that’s stuck with a Power-ON (BIOS) password. The laptop has very limited info available and I suspect it may be a local (South African) Proline board. Thought I’d check here in case anyone has seen this one before.
What I have:- Model: Proline NoteBook V146GNK
- Board: SU_GN100_MB_V12_20231120A
- Serial: GN10Q12124205W1588
- Notes: 12V main board. Very little documentation available.
What I’d like to request:- Has anyone dealt with this Proline board before or seen matching BIOS/firmware
by fx1982Hi everyone, can someone please help to remove bios Administrator password or decode as I failed miserably... Tried reading the password but it says wrong password. Thank you in advance!
It's a 2024 Asus Zephyrus G16
GU605MV
SN: S2NRCX035924088
CN: AEDW
MFD: 2024-02 36M
BIOS VERSION: 315...-
- Loading...
