Need Bios lenovo thinkpad E550
  • Rhork
    • Apr 2020
    • 28
    • France
    Lenovo e550 keyboard problem, dump bios ?
    I have a keyboard problem on a lenovo e550, so it's not the keyboard itself having tested another functional one. And same problem with some keys that do not work.
    I think it's an EC problem but I don't have anything to program it.
    I tried several dump bios but always the same problem
    Is there any way to do something with the bios? Or the only solution is to reprogram it or change it?
    I link the bios
    Thanks in advance
    • peste
      • 12887
      • ROMANIA
      Re: Lenovo e550 keyboard problem, dump bios ?
      I link the bios
      Thanks in advance
      if it has a dedicated video card, disable the video driver and see what happens, if it's ok, the video card or video memory is having problems, if it has the same problem, change and rewrite the I / O chip.
      • Rhork
        • Apr 2020
        • 28
        • France
        Re: Need Bios lenovo thinkpad E550
        Hi, no i'dont have a dedicated video card ;(
          • 21048
          Its unlikely to be a bios issue.Check all the keyboard connector pins are soldered properly,push each one slightly,check for corrosion and crud on the pins,clean them with isopropyl .You can check for continuity as well between each connector pin and the pins on the EC chip.If verything is ok then the EC should be programmed or you can buy a pre-programmed chip to solder on.The schematic is available https://www.badcaps.net/forum/showthread.php?t=70317.
          • Rhork
            • Apr 2020
            • 28
            • France
            I don't think it's a bios problem either, I wanted to know if it was possible to reset the EC via the bios I thought I saw that some time ago.
            I have already looked at the motherboard in detail under the microscope no worries at this level, on the other hand yes good idea to look at the continuity with the EC pins and the connector not thought, otherwise yes I would not have the choice either to equip myself or find someone who does.
            • Rhork
              • Apr 2020
              • 28
              • France
              #26
              Thank you for the information after having looked in detail I had the last two connections 31 and 32 that moved and the 32 is even broken more than to remake them and find the right connector (another story! )
              So a big thank you
              • max2711
                • Jan 2012
                • 62
                • Croatia
                #27
                Lenovo E550 bios repair
                please, repair my bios
                Black screen after win update
                Lenovo E550
                AITE1 NM-A221
                Rev: 1.0
                Thank You
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11817
                  #28
                  Re: Lenovo E550 bios repair
                  Lenovo E550
                  AITE1 NM-A221
                  Rev: 1.0
                  Thank You
                  repair
                  Mį»i khoįŗ£n quyĆŖn góp cho badcaps đều được hoan nghĆŖnh, hĆ£y nhįŗ„p vĆ o liĆŖn kįŗæt nĆ y Ä‘į»ƒ quyĆŖn góp. Cįŗ£m Ę”n tįŗ„t cįŗ£ những ngĘ°į»i į»§ng hį»™----------------------------------------------------------------------------------------------------------------------------------------------------------------
                  • max2711
                    • Jan 2012
                    • 62
                    • Croatia
                    #29
                    Originally posted by hoaca388
                    repair
                    it works!!!
                    Thank You
                    • Alexis01
                      • Oct 2019
                      • 13
                      • Philippines
                      #30
                      Lenovo Thinkpad E550
                      Can anyone help me with my BIOS clean or repair. Unit no display after update.
                        • 21048
                        Re: Lenovo Thinkpad E550
                        The serial number is required,as per the rules - https://www.badcaps.net/forum/showthread.php?t=103570
                        • Alexis01
                          • Oct 2019
                          • 13
                          • Philippines
                          #32
                          Sorry. here is the serial for my unit PF0BS7X4. Thank you.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11817
                            #33
                            https://www.badcaps.net/forum/showpo...6&postcount=28
                            • rex98
                              • Feb 2023
                              • 1280
                              • Mandaue CEBU, Philippines
                              #34
                              if anyone needed this it works 100%. it also has EC for KB problem.
                              • Mamabearcj88
                                • Feb 2025
                                I’m new here. Quick question. I have a E550, recently updated Window. I have a power on password. Not sure what happened but now it will not allow me to type the full password. The last character is a ā€œ!ā€ When I try to type it, it just beeps. The FN key is locked. Not sure if that matters. Bear with me on this please
                                • mo000
                                  • Nov 2017
                                  • 278
                                  • algeria
                                  #36
                                  hi
                                  i have lenovo thinkpad e550 Type 20DF - Model 20DF00CPMH
                                  with supervisor password
                                  how to remove the password ?
                                • lucaszmn
                                  by lucaszmn
                                  Problem:
                                  Initial Findings:
                                  • I concluded that the
                                  08-12-2025, 03:01 PM
                                • 1g0r
                                  Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                  by 1g0r
                                  First, the data in brief:
                                  Manufacturer: Lenovo
                                  Model: ThinkPad L15 G3 21C3-0016GE
                                  motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                  IC Bios 1: MX77L25650F
                                  IC Bios 2​: MX25L25673G
                                  EC Chip: NPCX997KAABX
                                  So far I've been a silent reader, but now I need your help
                                  I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                  I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                  The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                  01-18-2025, 02:39 AM
                                • MaxonDomkrat
                                  Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                                  by MaxonDomkrat
                                  Hi everyone.
                                  I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                                  07-30-2025, 01:27 PM
                                • RMDUiFT
                                  Should I buy a Lenovo Thinkpad E495 with bios password?
                                  by RMDUiFT
                                  Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                  I have a few questions:
                                  • If I would buy this laptop and have
                                  08-25-2024, 09:00 AM
                                • akwky
                                  by akwky
                                  Hi!
                                  04-14-2025, 01:56 PM
