Asus x540bp AMD bios please
  • maybel
    • Dec 2017
    • 24
    • philippines
    Re: Asus x540bp AMD bios please
    thanks PESTE
    • abdelilahocs
      • Nov 2018
      • 119
      • morroco
      pasword pls
      backup of bios
      x540bp rev 2
      • hardware1
        • Sep 2021
        • 2892
        • N/A
        Originally posted by abdelilahocs
        pasword pls
        backup of bios
        x540bp rev 2
        Try this Password: 1234
        or this Password: 147
        all donations are welcome,
        • abdelilahocs
          • Nov 2018
          • 119
          • morroco
          1234 not working
          147 work perfect
          thanks a lot
          • gunyt
            • Mar 2023
            • cordoba
            Originally posted by peste
            try..
            Tanks!, work for me.
            • ahkh_72
              • 103
              • Iran
              #26
              hi
              my laptop model is X540BA-DM734
              Mainboard number: x540bp rev:2
              SN:L8N0GR03A24835E
              CPU :AMD A4
              I need to replace the io chip (it8995e-128) with a new one(the old one is burnt). i need its data to program , but i cant find it in internet.
              i attach here its bios dump,
              can any on extract EC from main bios for me?
              Thanks.
              .Today should be different from yesterday.
            • K53ww
              • Jun 2024
              • 7
              Hi, please assist with X540BP, locked AMD bios
              ser:L7N0GR02A933299
              • peste
                • Dec 2016
                • 12254
                • ROMANIA
                #28
                ser:L7N0GR02A933299
                ADMIN PASSWORD PASSWORD22
                BOOT PASSWORD PASSWORD22
                • K53ww
                  • Jun 2024
                  • 7
                  Thank you Peste
                  • yelrah28
                    • Jun 2024
                    • Philippines
                    #30
                    Hi good day. Can someone please rebuild my bios. Asus X540BP Rev 2.0. Thank you in advance.
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • throwaway327
                    by throwaway327
                    Model No: RC72LA
                    Serial No: SBNVKD001014459
                    06-18-2025, 05:52 PM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • lrouw84
                    by lrouw84
                    Hi there,
                    01-28-2023, 01:31 PM
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
