Asus X750JN rev 2.0 bios dump Please
  • casti3l
    • Mar 2014
    • 95
    • romania
    Please help.
    Need urgent bios dump motherboard Asus X750jn rev 2.0 with video card nvidia 840m
    Here is the old bios that i have
  • casti3l
    • Mar 2014
    • 95
    • romania
    Re: Asus X750JN rev 2.0 bios dump Please
    Originally posted by casti3l
    Please help.
    Update:
    Here is the the one that I've found, test an work 100%
    • Auridice
      • 5
      • Ucayali
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
