Need bios Acer DAZAAMB16E0 F5-573
  • dougmaycjk
    • Oct 2017
    • 16
    • Brazil
    Hi guys, please, help me with a problem.
    I need a help with this laptop. I tried 3 different files, but doesn't work. I read than this laptop is a shi* for bios, is necessary the correct and edited file. Can you help me, guys?
    The original files is in attachment.
  • crowntoy99
    • Oct 2012
    • 264
    • india
    Re: Need bios Acer DAZAAMB16E0 F5-573
    try this
    • dougmaycjk
      • Oct 2017
      • 16
      • Brazil
      Originally posted by crowntoy99
      try this
      Did not work.
      I used both.
        • 20318
        Try this one .Flash your old EC back .
        D 218000
        W 21F000
        • dougmaycjk
          • Oct 2017
          • 16
          • Brazil
          D 218000
          W 21F000
          Did not work. I have a blink on screen. But, without image.
            • 20318
            Ok, try this one .
            • dougmaycjk
              • Oct 2017
              • 16
              • Brazil
              Ok, try this one .
              Did not work too. I have all voltage on the board, but, just a blink.
              • dougmaycjk
                • Oct 2017
                • 16
                • Brazil
                I have activity using acer auto update, by a pen drive using FN+ESC key. But, there are some archives than have multiples files, like ZAA_multi.fd, ZAA2_multi.fd....
                How to use that files?
                • jepeto59
                  • Jul 2024
                  • 3
                  • france
                  Hello, I don’t know how to create a new post.
                  Despite this, I have a problem with my Acer F5 573G equipped with an i5 7th gen and a gtx 940mx.
                  Board reference: DAZAAMB16E0 REV:E
                  The computer turns on, the fan and the hard drive turns. the screen is functional but I have no display even in HDMI/ VGA.
                  I tried to flash a bios of this forum but without success,
                  nevertheless if someone has a trick to fix it and give me a . bin file for my specific model.​
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11209
                    • Viet Nam
                    Serial number ?
                    • Nurshad
                      • Oct 2019
                      • 75
                      • bangladesh
                      Acer DAZAAMB16E0 F5-573 i3 6th bios need
                    • peste
                      • Dec 2016
                      • 12262
                      • ROMANIA
                      ​post the S/N,the original bios of the laptop even if it is corrupted,the full name and model of the laptop,etc..
                      • jepeto59
                        • Jul 2024
                        • 3
                        • france
                        hello , I found the bios and it is indeed an i5 , I saved the original bios and injected another , nevertheless still the same problem , but I found a motherboard in good condition at a low price, we will see if everything goes well , again thank you to the forum
                        • jepeto59
                          • Jul 2024
                          • 3
                          • france
                          for info the model is: F5-573G-57DS , SN: NXQD4EF008 the original bios is attached
                          • jomerfx28
                            • May 2020
                            • 31
                            • n/a
                            Laptop Running then power cuts-off, now laptop has not turning on, charging lights on, voltages are ok
                            Acer Aspire f5-573
                            Model : N16Q2
                            S/N: NXGD8EM0087062189F7600
                            Mfg Date: 2017/02/12
                              SMDFlea commented
                              Editing a comment
                              Thread merged.
                          • shiyab
                            • Sep 2023
                            • 1235
                            • india
                            Acer Aspire f5-573
                            Model : N16Q2
                            hi try
                            • jomerfx28
                              • May 2020
                              • 31
                              • n/a
                              Originally posted by shiyab
                              hi try
                              hi, did not work properly.
                              i need to live the device plug in for couple of hours and try like faking its full charge, removed charger and plug in, it can have a success rate of 80% to power on, serial is lost also in the bios
                              maybe this will help
                              Acer Aspire f5-573
                              Model : N16Q2
                              Mfg Date: 2017/02/12​
                              Model: ZAAX32
                              DAZAAMB16E0 REV: E
                              i will returned back the original bios and ill check, if i can replicate to turn it on, client states, device was turning on without a battery before.
                              • krot72
                                • Nov 2018
                                • 6
                                • Belgium
                                I flashed every bios from this topic - all working. Thanks to everyone for your help.
                                • Wg188
                                  ACER Veriton Z4660G AIO bios help
                                  by Wg188
                                  I have an Acer veriton Z4660G all in one pc,
                                  Model: Z4660G-I5850H1 (VZ4660G_W)
                                  Need bios dump and schematic would save my life !
                                  to make a long story short I bought this all in one used
                                  with a broken lcd, with the objective of making a custom desktop out of it
                                  ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                                  06-17-2023, 02:20 PM
                                • James194zt
                                  Acer Nitro 50-640E Corrupted BIOS Dump
                                  by James194zt
                                  My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                                  All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                                  04-28-2025, 03:29 PM
                                • ebyte64
                                  Bios request for Acer P214-52-58CH
                                  by ebyte64
                                  Good day.
                                  I would like to request a bios for the following laptop?
                                  Model: Acer P214-52-58CH
                                  Model No: N19Q7
                                  S/N: NXVLHE0H11204BA27600
                                  SNID: 11201936276
                                  Symptoms: Laptop powers on but no picture on screen.
                                  I have already checked voltages and all is present. I have checked resistance on the coils to see if the chipset or cpu might be shorted. All resistances look normal. I have tried diffrent ram and I have reset the bios. I have also visually inspected the board to see if anything is burnt or if there are any traces of liquid...
                                  09-25-2024, 05:59 AM
                                • Vesko356
                                  by Vesko356
                                  08-11-2023, 03:27 AM
                                • verniumEN
                                  Acer Extensa 15 EX215-23-R7NG - BIOS, badly need help :(
                                  by verniumEN
                                  My laptop model is EX215-23-R7NG
                                  BIOS chip XM25QU128C
                                  Here is my original bin file, as well as how the BIOS chip looks like
                                  My situation is if I press my laptop power on, fan turns on for the first five seconds and turns off, no display (not even acer), but power indicator is on, and the CPU gets warm, even caught one time if powered on for long (before an hour) the fan turns on again, is it only right that I'm approaching via BIOS?
                                  Before I got into this situation, I was just watching movies, and while turned on, pressed the battery reset button and cleaned...
                                  04-21-2025, 02:31 AM
