Need bios Acer DAZAAMB16E0 F5-573
  • dougmaycjk
    • Oct 2017
    • 16
    • Brazil
    Hi guys, please, help me with a problem.
    I need a help with this laptop. I tried 3 different files, but doesn't work. I read than this laptop is a shi* for bios, is necessary the correct and edited file. Can you help me, guys?
    The original files is in attachment.
  • crowntoy99
    • Oct 2012
    • 267
    • india
    Re: Need bios Acer DAZAAMB16E0 F5-573
    try this
    • dougmaycjk
      • Oct 2017
      • 16
      • Brazil
      Originally posted by crowntoy99
      try this
      Did not work.
      I used both.
        • 21662
        Try this one .Flash your old EC back .
        D 218000
        W 21F000
        • dougmaycjk
          • Oct 2017
          • 16
          • Brazil
          D 218000
          W 21F000
          Did not work. I have a blink on screen. But, without image.
            • 21662
            Ok, try this one .
            • dougmaycjk
              • Oct 2017
              • 16
              • Brazil
              Ok, try this one .
              Did not work too. I have all voltage on the board, but, just a blink.
              • dougmaycjk
                • Oct 2017
                • 16
                • Brazil
                I have activity using acer auto update, by a pen drive using FN+ESC key. But, there are some archives than have multiples files, like ZAA_multi.fd, ZAA2_multi.fd....
                How to use that files?
                • jepeto59
                  • Jul 2024
                  • france
                  Hello, I don’t know how to create a new post.
                  Despite this, I have a problem with my Acer F5 573G equipped with an i5 7th gen and a gtx 940mx.
                  Board reference: DAZAAMB16E0 REV:E
                  The computer turns on, the fan and the hard drive turns. the screen is functional but I have no display even in HDMI/ VGA.
                  I tried to flash a bios of this forum but without success,
                  nevertheless if someone has a trick to fix it and give me a . bin file for my specific model.​
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12268
                    Serial number ?
                    • Nurshad
                      • Oct 2019
                      • 75
                      • bangladesh
                      Acer DAZAAMB16E0 F5-573 i3 6th bios need
                    • peste
                      • 13421
                      • ROMANIA
                      ​post the S/N,the original bios of the laptop even if it is corrupted,the full name and model of the laptop,etc..
                      • jepeto59
                        • Jul 2024
                        • france
                        hello , I found the bios and it is indeed an i5 , I saved the original bios and injected another , nevertheless still the same problem , but I found a motherboard in good condition at a low price, we will see if everything goes well , again thank you to the forum
                        • jepeto59
                          • Jul 2024
                          • france
                          for info the model is: F5-573G-57DS , SN: NXQD4EF008 the original bios is attached
                          • jomerfx28
                            • May 2020
                            • 31
                            • n/a
                            Laptop Running then power cuts-off, now laptop has not turning on, charging lights on, voltages are ok
                            Acer Aspire f5-573
                            Model : N16Q2
                            S/N: NXGD8EM0087062189F7600
                            Mfg Date: 2017/02/12
                              SMDFlea commented
                              Editing a comment
                              Thread merged.
                          • shiyab
                            • Sep 2023
                            • 1592
                            • india
                            Acer Aspire f5-573
                            Model : N16Q2
                            hi try
                            • jomerfx28
                              • May 2020
                              • 31
                              • n/a
                              Originally posted by shiyab
                              hi try
                              hi, did not work properly.
                              i need to live the device plug in for couple of hours and try like faking its full charge, removed charger and plug in, it can have a success rate of 80% to power on, serial is lost also in the bios
                              maybe this will help
                              Acer Aspire f5-573
                              Model : N16Q2
                              Mfg Date: 2017/02/12​
                              Model: ZAAX32
                              DAZAAMB16E0 REV: E
                              i will returned back the original bios and ill check, if i can replicate to turn it on, client states, device was turning on without a battery before.
                              • krot72
                                • Nov 2018
                                • 6
                                • Belgium
                                I flashed every bios from this topic - all working. Thanks to everyone for your help.
                                • EbrahimSiami
                                  Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                  by EbrahimSiami
                                  I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                  **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                  **What I have tried so far:**
                                  1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                  07-02-2025, 02:31 PM
                                • Wg188
                                  ACER Veriton Z4660G AIO bios help
                                  by Wg188
                                  I have an Acer veriton Z4660G all in one pc,
                                  Model: Z4660G-I5850H1 (VZ4660G_W)
                                  Need bios dump and schematic would save my life !
                                  to make a long story short I bought this all in one used
                                  with a broken lcd, with the objective of making a custom desktop out of it
                                  ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                                  06-17-2023, 02:20 PM
                                • macabook
                                  by macabook
                                  🧩 Initial Issue
                                  07-24-2025, 02:17 PM
                                • James194zt
                                  Acer Nitro 50-640E Corrupted BIOS Dump
                                  by James194zt
                                  My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                                  All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                                  04-28-2025, 03:29 PM
                                • ub6ib969
                                  Acer Predator PO3-650 BIOS can someone help convert .CAP to .BIN ?
                                  by ub6ib969
                                  Model Number: PO3-650
                                  Part Number: DG.BK4AA.006
                                  Serial Number : 33400117730
                                  BIOS IC : XM25QH256C
                                  I have uploaded the bios from the acer website and the extracted bios from the board. Any help would be appreciated...
                                  07-02-2025, 03:51 PM
