Asus S300CA Bios
  • razadom
    • Apr 2015
    • 106
    • Madagascar
    Asus S300CA Bios
    Hi all
    I have problem with asus s300ca mb version 2.0 no gfx voltage but
    all others seems good. Can you provide working bios. I have tested
    dump from this forum but the problem is persist. I'll join old dump
  • eikspaj
    N1NJ4W4RR10R
    • Mar 2015
    • 135
    • Philippines
    Re: Asus S300CA Bios
    try this
    There are 10 types of people in the world. Those that understand binary and those that don't.
    • razadom
      • Apr 2015
      • 106
      • Madagascar
      Thanks for responding my message. I will try this and tell you the results.
      Thanks in advance
      • razadom
        • Apr 2015
        • 106
        • Madagascar
        Hi man
        I've tried your bin but the result is same. no voltage on gfx coil. Maybe someone
        can share another good dump for this
          • 22279
          Originally posted by razadom
          Hi man
          https://www.badcaps.net/forum/attach...3&d=1496441045
          • razadom
            • Apr 2015
            • 106
            • Madagascar
            Hi SMDFlea
            I have already tested this dump and no results. Can you suggest another bin.
            Thanks in advance
              • 22279
              Try this bios, idon`t think your problem is with the bios though.
              • razadom
                • Apr 2015
                • 106
                • Madagascar
                Hi SMDFlea
                I've already changed the two mosfets but there were no voltage on gfx coil.
                CPU voltage is ok. The cpu and the gfx use the same controller so i don't understand
                why the voltage won't start on this coil. I'll try your dump and tell you the result.
                • red_apache
                  • Mar 2014
                  • 9
                  • indonesia
                  Bios working for me.. Thx..
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
