Asus X510UNR
Serial Number - JAN0CX027512416
CN:YA8SComment
X510UFAttached Filesif you find these attachements useful please consider making a small donation to the site
​https://www.badcaps.net/donateComment
Can anybody fix this Bios?
Laptop working fine but it suddenly restarts.
daxkgcmb8a0 rev a
X510UN Rev 2.0
S/N - H9N0CX03429436G
X510UNRAttached Filesif you find these attachements useful please consider making a small donation to the site
My solution at # 45Originally posted by shamaltech
I tried with this bios but same problem.
Any solution?↵
please working bios for me
Asus S5100U
Board Part Number: X510nur ver 3.0
Serial Number:J4N0CX074361167 CN:XBW5
upload old bios
Please read the rules https://www.badcaps.net/forum/troubl...before-posting
and type the laptop serial number
for anyone reading this on 20250910... if you tried a bios from this tread and still no image on screen and everything seems to be fine, and if by any chance you get image on by HDMI try this... remove the screen and make sure the connection on the back on the LCD is properly connected, after trying a lot of bios versions I had to remove the screen and I noticed that the port was half way out on one of the corners, thus no image... just to make sure I was not loosing my time I tested the screen with a edp display tester and the screes was working fine... last thing to do is to connect properly the screen and cable and securing it with a little bit of tape(lots of it to prevent this little fkr to disconnect again) connected everything back again and the screen is detected and working fine. just before try any bios flash make sure you have all the things properly connected and I blame ASUS on this for not using metal braces to prevent the cable to disconnect, at the same time I thank Asus for not having me to replace the motherboard and for all the people on this forum for dedicating their time to put working bios up so we can test(one thing is sure, this laptop was not giving image or caps lock(usb keyboard with light, cuz this one has no state light.) activity before any of the bios I tried on this thread, so thanks again all of you and sorry for making you read this long post but I hope this helps youComment
I need a clean BIOS file for ASUS X510UNR Rev 3.0 (model X510UQ-BR632T).
The laptop has BIOS corruption and does not boot.
Details:
- Laptop model: ASUS X510UQ-BR632T
- Mainboard code: X510UNR Rev 3.0
- bios 8MB
Could someone please share the correct BIOS for this board?
Thank you very much in advance!Attached Filesif you find these attachements useful please consider making a small donation to the site
Thread merged. Post the serial number, please read the rules https://www.badcaps.net/forum/troubl...before-posting
Hi Can anybody fix this Bios?
Laptop isn't working at all, no charge light - 3.3, and 5 always is works fine, resistances overall also looks fine.
Asus R520U
Mainboard - X510UNR Rev 3.0
S/N - J9N0CX02120636BAttached Filesif you find these attachements useful please consider making a small donation to the site
Try, clean ME + BIOS 310 + DMI inserted
X510UAR
S/N J9N0CX02120636BAttached Filesif you find these attachements useful please consider making a small donation to the site
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by TyMercerApologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
Good Day Masters! Anyone have working bios for ASUS E410MA? i tried reading the BIOS Chip and the programmer cant detect it i think the bios chip is dead... i already tried 2 programmer but same still cant detect the chip. Thanks in Advance
Model: ASUS E410MA-TB.CL464BK
SN: N8N0CX06E199324
BoardModel: E410MA R7.1-
i need working bios for Asus x71SL the laptop work but it freez when enter to bios...
11-15-2025, 05:18 PM -
- Loading...
