Need bios LA-E811P
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Re: Need bios LA-E811P
Hi can someone please help me and fix my bios the laptop runs but no display
here is the original dump thanks in advance
Attached FilesComment
Open your bios with a hex editor and search for the word BID ,you`ll find your bios ID BID0832D . @peste has posted a virgin bios at post #17 . Open the virgin bios and your backup with a hex editor, copy the DMI and key from your backup to the new bios using these off-sets
DMI 200000 - 200FFF
W/K 202000 - 20203FComment
DMI 200000 - 200FFF
tthe BID0832D bios is extracted from the HP site, you will not find a better bios ... either you typed the bios with errors, or the bios posted by you is not the original of the laptop, or the laptop has other problems ... the interval for DMI and KEYWIN information you can find them in post # 28..try to write the bios again ...Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
tthe BID0832D bios is extracted from the HP site, you will not find a better bios ... either you typed the bios with errors, or the bios posted by you is not the original of the laptop, or the laptop has other problems ... the interval for DMI and KEYWIN information you can find them in post # 28..try to write the bios again ...Comment
Re: La-e811p rev 1.0 25Q64FWSIQ need BIOS please
tryAttached FilesComment
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by maanee11Hello Everyone,
I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...-
Hello to all of you! I need help with a BIOS file.
The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.-
- Loading...
