EPK50 LA-G07EP REV 1 bios
  • peste
    • Dec 2016
    • 13420
    • ROMANIA
    Re: EPK50 LA-G07EP REV 1 bios
    Originally posted by Ripukas
    Hi, how you identify bios variant? maybe you have EC (ene) file?
    EPK50 LA-G07EP
    you need the HxD program, you can find it on the net for free .... enter the bios in the program ... click "search", a window will open, write in it the word "bid" and press "ok", press the F3 key three times and you have reached the bios version..go to post # 13 and take the version you need from there ..
    • irvingcleto
      • Jun 2021
      • 7
      • Dominican Republic
      Hi. I'm a noob, please help me. I opened my original bin file in HxH -after reading it and saving it with a CH341A programmer-, followed your steps and after hitting f3 three times I don't see anything resembling the versions on post #13 you mentioned, so I'm stuck. I'm giving my laptop info and posting the original corrupted .bin file as well, in case you can help identify what version I need.
      Laptop model: HP 15-da0077nr
      Motherboard number: EPK50 LA-G07EP Rev 2.0
      I'd be eternally grateful.
      • peste
        • Dec 2016
        • 13420
        • ROMANIA
        press the F3 key until you reach the BID version, in your case 084A6.
        • irvingcleto
          • Jun 2021
          • 7
          Thank you very much man. Another question: if I flash this bios, I'm not going to have my motherboard information loaded, right? Like serial number for example. If not, how can I modify the new .bin with the existing information from old bios?
          I'm assuming that with HxD I can do this, but the question is how.
          Thanks.
            • 21677
            Thank you very much man. Another question: if I flash this bios, I’m not going to have my motherboard information loaded, right? Like serial number for example. If not, how can I modify the new .bin with the existing information from old bios?
            I’m assuming that with HxD I can do this, but the question is how.
            Thanks.
            Post #13 by @peste has the DMI offsets that you can use to copy the DMI from your old bios to the new virgin bios (the end offset was wrong,i edited the post).Select the start and end offset in your old bios,then copy, select the same start and end offset in the new bios, paste-insert then save .
            210000 - 21103F
            • irvingcleto
              • Jun 2021
              • 7
              #26
              Great, I will try it now. Thank you.
              • irvingcleto
                • Jun 2021
                • 7
                #27
                Thank you guys, your instructions worked like a charm. I successfully programmed the corresponding .bin file from post #13 after modifying it with the motherboard info from old bios, however it did not solve my problem which is laptop hangs up during windows splash screen. I've had this problem before with a hp laptop and I solved it by recovering the bios with windows + B key on the keyboard, but this process did not work with this laptop, that's why I bought the programmer to give a shot, assuming this is a bios issue.
                Let me say here that the files provided by the people in this thread are 100% working and the information given is precise, the problem was my laptop. This info is helpful for everyone else looking for something like this.
                It did not work for my particular problem, but at least I learned something new. Thanks again guys, be well.
                • chandrakant
                  • Nov 2017
                  • 39
                  • india
                  #28
                  Thank u
                  • Atiq
                    • Dec 2017
                    • 78
                    • India
                    #29
                    Hello Friends
                    motherboard part no. EPK50 LA-G07EP REV 1
                    after removing battery it works for one time again we need to repeat same for display.
                    Can someone check the bios file please?
                    All help will be very appreciated.
                    Thank you...
                    • Mazorca
                      • Jan 2017
                      • 463
                      Try this file.
                      • Atiq
                        • Dec 2017
                        • 78
                        • India
                        #31
                        Originally posted by Mazorca
                        Try this file.
                        thank you for help me. I tried but facing same problem
                        • DWCS
                          • May 2021
                          • 49
                          • Sri lanka
                          #32
                          EPK50 LA-G07EP REV 1.0 Main and ec bios need cpu i3 cpu ID - sr3w0
                          8th gen
                            • 21677
                            8th gen
                            Please read posts 13,21 and 25 .Use a hex editor to find your BID in your bios backup (post #21) to find the matching virgin bios (post #13) ,then copy your DMI to the new bios (post #25)
                            • Mazorca
                              • Jan 2017
                              • 463
                              search for the text BID.
                              • rjsoft9
                                • Aug 2018
                                • 22
                                • India
                                #35
                                bios extracted from the HP site update, the laptop has six bios variants, yours is 084A6
                                DMI 210000-21103F
                                Thank you
                                • Johnson
                                  • Jun 2017
                                  • 9
                                  • Nigeria
                                  #36
                                  DMI 210000-21103F
                                  Hello friend,
                                  I've tried all the variants my laptop didn't still display. The worst of it is that processor isn't warming up nor the keyboard light blinking
                                  • peste
                                    • Dec 2016
                                    • 13420
                                    • ROMANIA
                                    #37
                                    Originally posted by Johnson
                                    Hello friend,
                                    either you have another defect, or you wrote the bios with errors... post the original bios... I hope you didn't delete it..
                                    • umeshherath
                                      • Aug 2022
                                      • Sri Lanka
                                      #38
                                      NEED HELP
                                      I WANT HP 15 EPK50 LA-G07EP Rev:1.0 EC FIRMWARE
                                      HP Notebook - 15-da0002tu
                                      • aldopc
                                        • Jul 2017
                                        • 468
                                        • Chilito
                                        #39
                                        Originally posted by umeshherath
                                        NEED HELP
                                        Ready Bro
                                          • 21677
                                          NEED HELP
                                          You MUST:
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
