Asus E203MA Rev 2.0
  • hoaca388
    Badcaps
    • Jan 2022
    • 12272
    Re: Asus E203MA Rev 2.0
    Originally posted by dikizahrudin
    Please repair my bios no display. if i flash with other bios laptop can display but serial number is blank. my serial on case is
    SN : K1N0CX014822015
    CN: 2C7E
    PLEASE CAUSE THE WINDOWS KEY IS ON THE BIOS DUMP
    Your original bios file does not contain serial no and windows key.
    • playmedia
      Playmedia
      • Jul 2018
      • 20
      • United Kingdom
      Hi, can anyone help me with my bios for e203ma rev 2
      Ihave no display after windows update. I will post my original bios.
    • peste
      • Dec 2016
      • 13436
      • ROMANIA
      read..https://www.badcaps.net/forum/troubl...before-posting
      • playmedia
        Playmedia
        • Jul 2018
        • 20
        • United Kingdom
        Hi, the laptop is asus E203MA-FD017TS SN:KAN09R493434 AND THE BOARD IS E203MA REV 2
        • peste
          • Dec 2016
          • 13436
          • ROMANIA
          try..
          • playmedia
            Playmedia
            • Jul 2018
            • 20
            • United Kingdom
            #26
            Originally posted by peste
            try..
            Worked perfestly, thank you..
            • rachidell
              • Aug 2016
              • 140
              • algeria
              #27
              hi
              i need bios for asus e203m
              e203ma-FD004TS
              SN L2N0CX04869009E
              no display
              • peste
                • Dec 2016
                • 13436
                • ROMANIA
                #28
                Originally posted by rachidell
                hi
                e203ma-FD004TS
                SN L2N0CX04869009E
                no display
                try post#26..
                • angerian
                  • Sep 2021
                  • philippines
                  #29
                  try...
                  thanks its working in my asus e203m, no display problem
                  • Sukransyah
                    • Dec 2024
                    • 4
                    • Indonesia
                    #30
                    Please help to remove password
                    E203MAH-FD411T 201902
                    sn: K2N0CX03833608H
                    CN: 5YJR
                    • shiyab
                      • Sep 2023
                      • 1592
                      • india
                      #31
                      sn: K2N0CX03833608H
                      CN: 5YJR
                      hi try
                      • Sukransyah
                        • Dec 2024
                        • 4
                        • Indonesia
                        #32
                        Originally posted by shiyab
                        hi try
                        won't boot up
                        • Sukransyah
                          • Dec 2024
                          • 4
                          • Indonesia
                          #33
                          won't boot up
                          tried post #26 boot but no display
                          • shiyab
                            • Sep 2023
                            • 1592
                            • india
                            #34
                            won't boot up
                            try its new file
                            • Sukransyah
                              • Dec 2024
                              • 4
                              • Indonesia
                              #35
                              try its new file
                              boot, but no display
                              • razor_amd
                                by razor_amd
                                12-15-2020, 07:07 PM
                              • DynaxSC
                                by DynaxSC
                                06-14-2024, 03:49 PM
                              • Ahari
                                by Ahari
                                I...
                                08-13-2025, 06:12 AM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
                              • ArkzG
                                [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                by ArkzG
                                Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                What I currently have available:
                                - Model: FA506NF (2021)
                                - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                - Tools: CH341A programmer ready to use
                                Does anyone have either a clean 2MB .bin dump of this model,...
                                09-26-2025, 09:34 PM
