please i need bios dump for asus x75vd rev 2.0
  • antoska
    • Jul 2019
    • españa
    cpu i5
  • eikspaj
    N1NJ4W4RR10R
    • Mar 2015
    • 135
    • Philippines
    Re: please i need bios dump for asus x75vd rev 2.0
    that bios is already posted here...
    https://www.badcaps.net/forum/showth...ighlight=x75vd
    There are 10 types of people in the world. Those that understand binary and those that don't.
    • antoska
      • Jul 2019
      • españa
      Thanks, I already installed it but the Geforce 610m keyboard and graphics card does not work, it does not detect it. Thank you for answering
      • peste
        • 13924
        • ROMANIA
        try..
        • antoska
          • Jul 2019
          • españa
          ok friend thank you have if you don't give me problems
          • TECHO TN
            • Jan 2024
            • 72
            • algeria
            try..
            Thank you working 100%
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
