Dell XPS M1330 system assword
  • gsmtim
    • Oct 2018
    • 33
    • philippines
    hi guys i'm tired to flash the bios but not working still lock for system password. anyone have this idea to remove this system password?
    thanks in advance.
    //herbert
  • peste
    • 13915
    • ROMANIA
    Re: Dell XPS M1330 system assword
    maybe it helps you...
    https://www.badcaps.net/forum/showthread.php?t=25909
    • gsmtim
      • Oct 2018
      • 33
      • philippines
      thank you sir it's working
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
        Dell Thunderbolt Firmware
        by SMDFlea
        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
        The SKU is in brackets (****)
        EDIT: NVM65...
        01-26-2025, 06:22 AM
      • dell_sadness
        Dell Latitude 3440 - Service tag ending in 0001 - Locked!
        by dell_sadness
        BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
        Have extracted the BIN and want to know how to rebuild a clean BIOS
        I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
        I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
        Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
        11-12-2025, 02:54 PM
