Need Bios Asus x450cc
  • qonma
    Kuli Solder
    • Jun 2017
    • 184
    • INDONESIA
    need bios asus x450cc rev 2.3 non vga ( vga intel )
    this ori bios
    thanks
  • peste
    • Dec 2016
    • 12729
    • ROMANIA
    Re: Need Bios Asus x450cc
    try...
    • qonma
      Kuli Solder
      • Jun 2017
      • 184
      • INDONESIA
      Originally posted by peste
      try...
      thankyou brother
      • qonma
        Kuli Solder
        • Jun 2017
        • 184
        • INDONESIA
        still no display, in power supply only up 0,735amper
        • qonma
          Kuli Solder
          • Jun 2017
          • 184
          • INDONESIA
          before switch on the lamp indicator running on
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Check consumption without ram stick. Is it same??
            • qonma
              Kuli Solder
              • Jun 2017
              • 184
              • INDONESIA
              ram onboard, am cek normaly voltage in capacitor near ic ram
              • maryanta
                • Aug 2022
                • 23
                • indonesia
                thank you brother
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • lrouw84
                  by lrouw84
                  Hi there,
                  01-28-2023, 01:31 PM
