DELL latitude 7390 bios dump
  • minhdigital
    • Nov 2022
    • 728
    • Vietnam
    #101
    Originally posted by cavalierks
    any one can unlock rhis plz
    la-f312p rev 2.0
    dell 7390
    STAG CPK95S2
    Send to you
    • IMLJ
      • Jan 2015
      • 21
      Bios password removal needed. thanks.
      LA-311P Rev 3.0
      Service Tag:7915pV2
      • minhdigital
        • Nov 2022
        • 728
        • Vietnam
        #103
        LA-311P Rev 3.0
        Service Tag:7915pV2
        Send to you
        • IMLJ
          • Jan 2015
          • 21
          Originally posted by minhdigital
          Send to you
          thaks so much, it works.
          • Spikeman
            • Nov 2021
            • 11
            • Italy
            #105
            Hello everyone.
            Dell Latitude 7390 I5-8TH
            LA-F312P Rev: 2.0 (A01)
            s/n 3WJM5S2
            LEDs flash at startup, no screen.
            I probably (if this is possible) damaged the bios chip because I forgot to remove the batteries.
            In fact the chip is not automatically detected and even by putting a similar bios I cannot do the dump with Ch341A. (only 0).
            I suspect that the Chip is burnt, I would like to buy a blank one on ebay, but I don't know which one to get for these two reasons:
            1. chip model not perfectly readable (doesn't even seem to be winbond)
            2. There are two chips with 8 pins (as visible in the photo)
            That the real bios is on the opposite side from where the ram is?
            Thanks for giving me help.
            image 1: I think it's the bios chip (it's the one attached to the post)
            image 2 the other chip with 8 pins.
            • Spikeman
              • Nov 2021
              • 11
              • Italy
              #106
              Originally posted by Spikeman
              Hello everyone.
              s/n 3WJM5S2
              I did some research and figured out which bios chip. So I performed the dump and very hopefully I wanted to write a bios test that you have already released in this thread.
              But with desolation I see that they are all around 8Mb, while mine is 16Mb. So it doesn't seem very convenient to me to delete the 16Mb bios to write an 8Mb bios over it.
              I read that: "EC/ME FW on 8Mb and Bios Region on 16Mb". So I'm wondering what should I do.
              Thank you
              Since I find it inconvenient for the forum to upload a 16mb file, it also seems like I don't have permission to upload a .bin file, maybe I should zip it?
              I uploaded it online anyway
              Bios dump: 7390.bk.bin
            • Markus1741
              • Sep 2020
              • 843
              • N/A
              #107
              Hello two things UT6 chip is for Thunderbolt interface stay away.
              Your BIOS is UC5 I did an ME clean of your BIOS you can program it and only that.
              You also can't program an 8MB BIOS on a 16.8MB chip, that's not possible.​
              To upload something create a RAR or ZIP file then it works too.​
              • Spikeman
                • Nov 2021
                • 11
                • Italy
                #108
                Originally posted by SMDFlea
                Yes, it should be zipped. No external links,read the rules - https://www.badcaps.net/forum/troubl...before-posting
                Yes, sorry, there was the functionality to attach via external URL which misled me.
                Thanks for the edit.
                Thanks for your time, but it's not working.
                However, before the white and orange LEDs flashed, now the LED turns off and the keyboard remains active with caps lock.
                However, something has changed.
                I tried removing the ram and it should correctly report a problem on the ram with white and orange flashing, so it detects the missing ram.
                I also tried changing the CMOS battery. Tried turning it on without any battery and did several tests.
                The Dell stops with the caps lock blocked.​
                • Markus1741
                  • Sep 2020
                  • 843
                  • N/A
                  #109
                  Try this new file, maybe it will help​.
                  Good luck ....
                  • ashr88
                    • Mar 2023
                    • 55
                    • United Kingdom
                    #110
                    Hi, I have a Latitude 7390 which appears to power but fails to post. I have dumped the two 1MB bios's and the 16MB bios. Do they need a repair?
                    Latitude 7390
                    DAZ20 LA-F311P REV 3.0 (A02)
                    Service tag:5QPMWT2
                    • piszpunta
                      • Jan 2019
                      • 249
                      • poland
                      #111
                      Latitude 7390
                      Service tag:5QPMWT2
                      try
                      • ashr88
                        • Mar 2023
                        • 55
                        • United Kingdom
                        #112
                        Originally posted by piszpunta
                        try
                        Thanks for that, unfortunately the file is corrupted so I cannot open it?
                        • ashr88
                          • Mar 2023
                          • 55
                          • United Kingdom
                          #113
                          try
                          Never mind, my PC corrupted it. I am flashing it now. Thank you.
                          • hollo13
                            • Mar 2017
                            • 21
                            • Hungary
                            #114
                            Hi,can anyone help repair this bios file? Power on ,no display
                            Dell Latitude 7390 I7 Gen8th Vpro
                            TAG : 249GLQ2
                            Mainboard code : DAZ20 LA-F312P REV 1.0
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11478
                              • Viet Nam
                              #115
                              TAG : 249GLQ2
                              Latitude 7390
                              Service Tag: 249GLQ2
                              • didouche1200
                                • Oct 2016
                                • 354
                                • 82679911441
                                #116
                                need bios for dell la-f312p service tag 5644xt2
                                ISSUE NO DISPLAY
                                  SMDFlea commented
                                  Editing a comment
                                  Thread merged.
                              • TGMT-CLT
                                • Aug 2023
                                • 6
                                • viet nam
                                #117
                                HELP ME! ISSUE CAN'TSTART, JUST FAN ON THEN OFF
                                TAG : 6T78HR2
                                • danito
                                  • Jun 2016
                                  • 844
                                  • Romania
                                  #118
                                  TAG : 6T78HR2
                                  try
                                  • struart
                                    • Aug 2022
                                    • 38
                                    • Poland
                                    #119
                                    Hello friends
                                    Laptop DELL Latitude 7390 no reaction.
                                    But when i flashed bios from this thread laptop started to be alive but restarts and fans are on all time.
                                    I dumped original BIOS.
                                    GD25B127DIG
                                    MB: LA-F312P REV 2.0
                                    Service TAG: 4Z5Z7S2
                                    Can someone take a look?
                                    • kalilinux25
                                      • Mar 2018
                                      • 2069
                                      • ZAMBOANGA SIBUGAY
                                      #120
                                      Originally posted by struart
                                      Hello friends
                                      GD25B127DIG
                                      Please try I already clean ME region and DMI added
                                      • gizaha
                                        by gizaha
                                        02-13-2024, 07:18 AM
                                        DELL Latitude 7390 Notebook 7000 Specification for Upgrade or Repair
                                        This specification for the DELL Latitude 7390 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7390 boardview and 7390 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7390...
                                        09-06-2024, 12:20 PM
                                        DELL Latitude 7390 Hybrid (2-in-1) 7000 Specification for Upgrade or Repair
                                        This specification for the DELL Latitude 7390 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7390 boardview and 7390 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                        09-06-2024, 11:14 AM
