DELL latitude 7390 bios dump
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
Re: DELL latitude 7390 bios dump
BIOS guides, methods, resources and tools
Password removal by laptop brand----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Read the rules before posting:
Add:- Service Tag.
- Original dump.
- Issue description.
Dell Latitude 7390
Reg Model: P28S
Reg Type: P28S002
System Number: 909CQQ2-E7AB
*Service Tag SN: 033759
Motherboard: DAZ20 LA-F312P Rev: 1.0 (A00)
*Issue description:
i need Clean up Password Bios
Many thanks in advance
*Original dump
Unlock Done
===============Last edited by DZ-Developer; 05-23-2023, 11:48 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------
see the donate button below, at the bottom of the page, or
Doctrina est fructus dulcis, radicis amaraeComment
This is the second time today I am making a remark for you to read the rules!
3.4. Dell
Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
See: https://beta.bios-pw.org/ .
Note: The 6FF1 suffix has a bug,use your service tag with the BF97 suffix instead,Example: 1234ABC-BF97
There is no publicly available 8FC8 generator available at the moment.
The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
.Last edited by Vesko356; 05-23-2023, 11:57 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------
dell latitude 7390 DAZ20 LA-F312p Rev : 2.0
PLEASE REMOVE PASSWORDAttached FilesComment
I have a Latitude 7390 which does not POST. I believe that it may be an BIOS issue.
Could someone please check the attached file and let me know if it's corrupted?
DAZ20 LA-F312P Rev:2.0
Service Tag: H6V95S2
Thanks in advance!Attached FilesComment
i have dell e7390
daz20 la-f312p rev3.0 bios bin, after i clear computrace, model change to 7290, pls any help i appriciate thanks
below is my orginal file
Service Tag: 6F4HL13Attached FilesComment
Re: DELL latitude 7390 bios dump - dont show nothing, power respond.
service tag 77qvvnn2 - hard to read
express code15705933230
can you fix this.
thanksAttached FilesComment
*when i press power - power led light up, nothing more.
no display, no fan that spin, so the laptop respond only when i press power.Comment
update
- tested other bios.
-when i press power - keyboard light up
- fan its spinin some second then turn off, if i pressit again, do same things.
-if i remove ram, diagnostic led blink white and yellow.
caps led dont change if i press itLast edited by darckreign1984; 07-28-2023, 07:39 AM. Reason: when power its pressed - usb its active some seconds then turn off (i have a usb memmory with a white led)Comment
ALL you know is to ask for help, you NEVER helped others! In 12 years on this forum you should have learned how to perform a clean ME. Badcaps veterans explained very well how to do it.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
thanks
*my account its old, buth i did not was active on this site.
*and even the older member of this forum, when they help me, they not succeed in the first attept.
thanks for remind me thr help problem (*i helped me and other with a small donation in the past).
Have a nice dayComment
I tried to follow the tutorial to clean my me bios laptop. However, it still behaves the same way as before. These are the results.
i use ME_Analyzer_v1.148.4_r209 because MEAnalyzer-r332 - converted to exe give me error about line 25 in phyton.
thanks.
old bios
║ Family │ CSE ME ║
║ Version │ 11.8.92.4222 ║
║ Release │ Production ║
║ Type │ Extracted ║
║ SKU │ Corporate LP ║
║ Chipset │ SPT/KBP-LP C ║
║ TCB Security Version Number │ 3 ║
║ Version Control Number │ 331 ║
║ Production Ready │ Yes ║
║ Power Down Mitigation │ No ║
║ Lewisburg PCH Support │ No ║
║ OEM Configuration │ No ║
║ Date │ 2022-02-07 ║
║ File System State │ Initialized ║
║ Size │ 0x603000 ║
║ Flash Image Tool │ 11.6.0.3307 ║
║ Latest │ Yes
new bios results
║ outimage.bin (1/1) ║
║ Family │ CSE ME ║
║ Version │ 11.8.93.4323 ║
║ Version Control Number │ 341 ║
║ Date │ 2022-06-29 ║
║ File System State │ Configured ║
║ Size │ 0x603000 ║
║ Flash Image Tool │ 11.8.50.3460 ║
║ Latest │ Yes ║
╚═════════════════════════════╧══════════════╝Attached FilesComment
service tag 77QWNN2
try this bios and feedbackAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
This specification for the DELL Latitude 7390 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7390 boardview and 7390 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7390...09-06-2024, 12:20 PM
This specification for the DELL Latitude 7390 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7390 boardview and 7390 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...09-06-2024, 12:20 PM
This specification for the DELL Latitude 7390 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7390 boardview and 7390 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7390...09-06-2024, 11:14 AM
- Loading...
