Need bios for hp mt44
  • NOoFEARoNL
    • Jan 2015
    • 13
    • netherlands
    Hi all i am searching for bios.bin file for elitebook mt 44 3JG87EA or from a laptop with same motherboard in it.
    Big thanks in advance..
    • 21675
    Re: Need bios for hp mt44
    Post your bios backup .
    • NOoFEARoNL
      • Jan 2015
      • 13
      • netherlands
      wil post as soon as possible thanks
      • NOoFEARoNL
        • Jan 2015
        • 13
        • netherlands
        The bios backup
          • 21675
          Originally posted by NOoFEARoNL
          The bios backup
          Can you make another backup,seems corrupt. Are you using a clip or desoldered the bios.
          • NOoFEARoNL
            • Jan 2015
            • 13
            • netherlands
            i use a clip i wil make new one thanks post i tomorow
            • NOoFEARoNL
              • Jan 2015
              • 13
              • netherlands
              a new backup from bios hope this one is okay
              • bhatt
                • Dec 2015
                • 95
                • pakistan
                HP MT44
                part number
                TRYPTICO 6050A2945701-MB-A0
                need hp mt44 ec patch file, without any error
                many time i try and make his ec bios but give
                ( security device problem error )
                • markv81
                  Markv
                  • 18
                  • Netherlands
                  Also have a HP MT44 Mobile Thin Client. with 2 bios chips:
                  Winbond 25Q128JVpQ
                  Winbond 25Q16JVSI0
                  which chip contains the bios password / which chip should i read ?
                  Thanks in advance, will send the serialnumber later.
                  • markv81
                    Markv
                    • 18
                    • Netherlands
                    Hi everyone 2nd post in this forum, I had a Laptop HP mt44 Mobile Thin client with MB:TRYPTICO 6050A2945701-MB-A01 with a password protected bios. I replaced the original Winbond WQ128JVPQ (UN_366,and UN367) for the WQ128JVSQ bit bigger and easier to solder (with hot air), I read the ic's with a hex editor and edit them and program the eeproms, I checked it, I reassembled them and I find the PC in this damaged state no display and the yellow power led is flashing on the side where the powerplug is in the laptop I tried rewriting the original files back but nothing changes. The connections are OK, I used a ch341, I can't explain what happened. Hope some 1 can help me. The voltages on the IC are OK and no shorts.....
                    Model: HP mt44 Mobile Thin Client
                    Serial: 5CG9020CKW
                    MB type:TRYPTICO 6050A2945701-MB-A01
                    See fore more specs: image hp MT44 SPECS.jpg
                    from all ic's i made a backup before de(soldering) see attachments
                    • peste
                      • Dec 2016
                      • 13420
                      • ROMANIA
                      Serial: 5CG9020CKW
                      if you wrote back the chips with the original bios, and it doesn't work, you must have read them with errors before..
                      • markv81
                        Markv
                        • 18
                        • Netherlands
                        I verified the buffer from what is in the bios chips and all are the same as in the bios chips (made several backups from each chip)
                        • BALAJI TRITECH
                          • Jun 2017
                          • 7
                          • INDIA
                          model : hp mt44
                          SN : 5CG92594ZZ
                          Prod id : 5JT04PA#AB4
                          Problem : bios password need to unlock
                        • markv81
                          Markv
                          • 18
                          • Netherlands
                          Originally posted by BALAJI TRITECH
                          model : hp mt44
                          SN : 5CG92594ZZ
                          try this:
                            • 21675
                            model : hp mt44
                            SN : 5CG92594ZZ
                            The bios you posted is from an 840 G6 with serial number 5CG02746NX .The serial you posted isn`t recognised at HP support .What model is the laptop ? , what is the mt44 , post the motherboard model number
                            • BALAJI TRITECH
                              • Jun 2017
                              • 7
                              • INDIA
                              try this:
                              Thank u So much . Password cleared
                              • markv81
                                Markv
                                • 18
                                • Netherlands
                                You're welcome. we are here to help each other.
                                • markv81
                                  Markv
                                  • 18
                                  • Netherlands
                                  I Think the problem is in the Winbond 25Q16JVSIQ bios chip becasuse all backups (4x) i made from this chip are a little different. Wrote all backups back in the chip, 4x no succes. is there a universal *.bin file 2048Kb (2MB) for this chip ?
                                  Serial: 5CG9020CKW
                                  Tried the universal *.bin file found on this website but no succes.....
                                  Some one knows how to get some live in his laptop.
                                  all messed up but first time i have this type of laptop
                                  • kalilinux25
                                    • Mar 2018
                                    • 2089
                                    • ZAMBOANGA SIBUGAY
                                    Serial: 5CG9020CKW
                                    Try this one
                                    • markv81
                                      Markv
                                      • 18
                                      • Netherlands
                                      Originally posted by kalilinux25
                                      Try this one
                                      Thnx wil try them tomorow and let you know.
                                      • Wutru
                                        HP Elitebook 820 G4 BIOS repair assistance required
                                        by Wutru
                                        Hi guys,
                                        If someone would be able to provide some expertise, I'd be very grateful.
                                        BIOS Corruption - Cause
                                        So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                        After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                        09-06-2025, 10:32 AM
                                      • STKR123
                                        The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                        by STKR123
                                        Greetings badcaps community,
                                        I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                        So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                        Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                        I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                        These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                        I learned that desoldering...
                                        10-29-2024, 06:03 AM
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • Guest
                                        Elitebook 850 G5 BIOS bricked
                                        by Guest
                                        I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                        I assume the BIOS update failed, so I searched for the BIOS chip.
                                        I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                        However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                        Can the corrupted...
                                        03-24-2025, 01:21 AM
                                      • lap-top123
                                        Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
                                        by lap-top123
                                        HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
                                        Hp Elitebook 850 G8
                                        ProdID 52W98EC#ABD
                                        SN# 5CG1458XQ7
                                        Mac-address #1: 84:14:4D:2C:4B:5B
                                        UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
                                        Mainboard : 6050A3216701-MB-A01(A1)
                                        08-20-2025, 07:28 AM
