Need bios for hp mt44
  • NOoFEARoNL
    • Jan 2015
    • 13
    • netherlands
    Hi all i am searching for bios.bin file for elitebook mt 44 3JG87EA or from a laptop with same motherboard in it.
    Big thanks in advance..
    • 20958
    Re: Need bios for hp mt44
    Post your bios backup .
    • NOoFEARoNL
      • Jan 2015
      • 13
      • netherlands
      wil post as soon as possible thanks
      • NOoFEARoNL
        • Jan 2015
        • 13
        • netherlands
        The bios backup
          • 20958
          Originally posted by NOoFEARoNL
          The bios backup
          Can you make another backup,seems corrupt. Are you using a clip or desoldered the bios.
          • NOoFEARoNL
            • Jan 2015
            • 13
            • netherlands
            i use a clip i wil make new one thanks post i tomorow
            • NOoFEARoNL
              • Jan 2015
              • 13
              • netherlands
              a new backup from bios hope this one is okay
              • bhatt
                • Dec 2015
                • 92
                • pakistan
                HP MT44
                part number
                TRYPTICO 6050A2945701-MB-A0
                need hp mt44 ec patch file, without any error
                many time i try and make his ec bios but give
                ( security device problem error )
                • markv81
                  Markv
                  • 18
                  • Netherlands
                  Also have a HP MT44 Mobile Thin Client. with 2 bios chips:
                  Winbond 25Q128JVpQ
                  Winbond 25Q16JVSI0
                  which chip contains the bios password / which chip should i read ?
                  Thanks in advance, will send the serialnumber later.
                  • markv81
                    Markv
                    • 18
                    • Netherlands
                    Hi everyone 2nd post in this forum, I had a Laptop HP mt44 Mobile Thin client with MB:TRYPTICO 6050A2945701-MB-A01 with a password protected bios. I replaced the original Winbond WQ128JVPQ (UN_366,and UN367) for the WQ128JVSQ bit bigger and easier to solder (with hot air), I read the ic's with a hex editor and edit them and program the eeproms, I checked it, I reassembled them and I find the PC in this damaged state no display and the yellow power led is flashing on the side where the powerplug is in the laptop I tried rewriting the original files back but nothing changes. The connections are OK, I used a ch341, I can't explain what happened. Hope some 1 can help me. The voltages on the IC are OK and no shorts.....
                    Model: HP mt44 Mobile Thin Client
                    Serial: 5CG9020CKW
                    MB type:TRYPTICO 6050A2945701-MB-A01
                    See fore more specs: image hp MT44 SPECS.jpg
                    from all ic's i made a backup before de(soldering) see attachments
                    • peste
                      • Dec 2016
                      • 12835
                      • ROMANIA
                      Serial: 5CG9020CKW
                      if you wrote back the chips with the original bios, and it doesn't work, you must have read them with errors before..
                      • markv81
                        Markv
                        • 18
                        • Netherlands
                        I verified the buffer from what is in the bios chips and all are the same as in the bios chips (made several backups from each chip)
                        • BALAJI TRITECH
                          • Jun 2017
                          • 7
                          • INDIA
                          model : hp mt44
                          SN : 5CG92594ZZ
                          Prod id : 5JT04PA#AB4
                          Problem : bios password need to unlock
                        • markv81
                          Markv
                          • 18
                          • Netherlands
                          Originally posted by BALAJI TRITECH
                          model : hp mt44
                          SN : 5CG92594ZZ
                          try this:
                            • 20958
                            model : hp mt44
                            SN : 5CG92594ZZ
                            The bios you posted is from an 840 G6 with serial number 5CG02746NX .The serial you posted isn`t recognised at HP support .What model is the laptop ? , what is the mt44 , post the motherboard model number
                            • BALAJI TRITECH
                              • Jun 2017
                              • 7
                              • INDIA
                              try this:
                              Thank u So much . Password cleared
                              • markv81
                                Markv
                                • 18
                                • Netherlands
                                You're welcome. we are here to help each other.
                                • markv81
                                  Markv
                                  • 18
                                  • Netherlands
                                  I Think the problem is in the Winbond 25Q16JVSIQ bios chip becasuse all backups (4x) i made from this chip are a little different. Wrote all backups back in the chip, 4x no succes. is there a universal *.bin file 2048Kb (2MB) for this chip ?
                                  Serial: 5CG9020CKW
                                  Tried the universal *.bin file found on this website but no succes.....
                                  Some one knows how to get some live in his laptop.
                                  all messed up but first time i have this type of laptop
                                  • kalilinux25
                                    • Mar 2018
                                    • 2089
                                    • ZAMBOANGA SIBUGAY
                                    Serial: 5CG9020CKW
                                    Try this one
                                    • markv81
                                      Markv
                                      • 18
                                      • Netherlands
                                      Originally posted by kalilinux25
                                      Try this one
                                      Thnx wil try them tomorow and let you know.
                                      • STKR123
                                        The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                        by STKR123
                                        Greetings badcaps community,
                                        I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                        So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                        Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                        I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                        These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                        I learned that desoldering...
                                        10-29-2024, 06:03 AM
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • Guest
                                        Elitebook 850 G5 BIOS bricked
                                        by Guest
                                        I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                        I assume the BIOS update failed, so I searched for the BIOS chip.
                                        I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                        However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                        Can the corrupted...
                                        03-24-2025, 01:21 AM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
