wdc hard drive password lock
+ More Options
Posts
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need to unlock this hard drive western digital password i failed to attempt 3 times this message comes(ENTER UNLOCK PASSWORD KEY:77955144
    • 21032
    Re: wdc hard drive password lock
    Laptop make, model .....
    • petehall347
      • Jan 2015
      • 4427
      https://bios-pw.org/
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        http://hugowan.blogspot.com/2012/05/...-password.html
        Im Back... sort of...
        • federalhouse
          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
          by federalhouse
          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
          **Background:**
          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
          **What I've Tried So Far:**
          1. I accessed
          08-01-2024, 07:03 PM
        • tmcw
          PC case - Hard drive rails
          by tmcw
          A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
          So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
          I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
          Now, the case is a CiT Gaming Case, and...
          05-22-2022, 12:04 PM
        • madura2010
          DAY11AM6E0 hard disk drive and optical disk drive not detected
          by madura2010
          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
          i checked the connectivity of ribbon=good communication with hard and motherboard
          changed hard disk and checked=3f0 error persist
          sata power=+5v available
          Then checked data capacitors=all good
          Then checked data lines path connectivity to pch=all good
          reflashed...
          03-12-2023, 09:09 AM
        • ash91
          Hp pavilion 15 not detect hard drive
          by ash91
          Hello gentelmen .... this is my first post and sorry for my bad english,
          so my proplem is my laptop keep losing hard drive even if i but the
          hard disk in the cady (the box that can replace the dvd rom with hard disk)
          when i turn the laptop on the massage that said no boot media found pop on
          the hard disk is fine and to be sure i try another hard
          i also update my bios to the last update
          the 5 volt is present on the hard connector on the motherboard
          the dvd rom work fine when i but a windows dvd in it
          also when i boot from flash...
          06-07-2023, 01:45 PM
        • Syseng
          Lenovo P14s Gen 5 SVP unlock
          by Syseng
          This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
          The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
          06-22-2025, 07:44 AM
