The proper bios version is GL553VE https://www.badcaps.net/filedata/fetch?id=3639498
Need bios asus gl553vd
Attached FilesComment
Thank you!! SMDFlea It worked With conditions.
So as mentioned i needed to shift data between drives and install fresh windows on ssd.
After flashing the bios, the bios worked ok, i was able to boot into my live usb by selecting from boot menu.
After booting,
i just format my old windows partition.
Shift data around. Etc. (Now without the live usb i donot have any bootable drive, in my pc)
Since then, i was unable to acess the boot menu again.😥
I was still able to boot into windows installer usb because it was the only boot option.
Now i cannot get into bios or boot menu, again. 😥
i got lucky.Comment
i messed up, i reflashed the bios given by SMDFlea after reinstalling (fresh) windows, now its stuck at Asus logo, cannot go into windows or bios, 🤣🤣
i looked it up - google response boot order issues, but i cannot do anything​
all i did was inserted my windows installer usb in hopes of trying to get reinstall windows again!
i looked it up - google response boot order issues, but i cannot do anythingComment
Adding a few bios images for the GL553VD as requested.
Hello. Asus GL553VD-FY009, bios busted after bios windows update failed
Now notebook is starting, but no picture on screen
SN H2N0CV179585084
Can you guys make me an revive? Thank you very much.
What model number does it say on the barcode sticker - https://www.badcaps.net/forum/troubl...10#post3307010
So. i search on this 5 pages of bios, and search inside file for therms "GL553VD" and i picked file named "Asus Rog GL553VD-F1 Rog GL553VD-F1_bios-version-302"
Write it, it's working perfect.
But, this file has SN named generaly "SSN1234567890123456", and because i did NOT know at what adress i find DMI, i proceed like this:
- i search in my messed up bios for original SN "H2N0CV179585084" and i find it from 2706D0 - 271D00
- i decided that DMI region is from 270100 - 271FF0, copy it in the new working bios, write it, BUT, in bios SN is still show the general one "H2N0CV179585084"
Please tell me how to find in future where is located DMI in a bin file.
Thank you.
Mate, it not say anything, because i did NOT take out mainboard, notebook has to be resolved low on money, like nothing...
Thank you.Comment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by MotherTeresaHello Could someone who knows about BIOS take a look at the attached dump. Laptop AUSU ROG GL552VW with nVidia N16P 4GB and i5 CPU.
I used to change GPU in the laptop, and it worked without problems for a few years. My 9-year-old daughter uses the equipment, yesterday it worked, today she says it won't start. I checked and it hangs on the ASUS logo, you can't enter BIOS (it worked once).
Disconnecting all peripherals, including the keyboard, resetting BIOS with jumpers under RAM, changing RAM does nothing, it still hangs on LOGO.
I installed a different BIOS from this model to... -
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
- Loading...
