Need bios asus gl553vd
    • 21381
    Originally posted by hoaca388
    ASUS FX553VE
    The proper bios version is GL553VE https://www.badcaps.net/filedata/fetch?id=3639498
      • 21381
      Originally posted by claws77
      this bios works with lcd and battery, keyboard, keyboard light and hdd and nvme and speaker and daughter board
      this bios does not work when trackpad is connected.
      serial no, model no both are wrong.
      same issues boooting from usb still persists.
      Try this bios, erase the chip before programming. And by the way, please do not post your bios in repair threads , all bios requests go here in the dedicated Bios requests forum.
      • claws77
        • Apr 2024
        • 103
        • India
        #83
        Thank you!! SMDFlea It worked With conditions.
        So as mentioned i needed to shift data between drives and install fresh windows on ssd.
        After flashing the bios, the bios worked ok, i was able to boot into my live usb by selecting from boot menu.
        After booting,
        i just format my old windows partition.
        Shift data around. Etc. (Now without the live usb i donot have any bootable drive, in my pc)
        Since then, i was unable to acess the boot menu again.😥
        I was still able to boot into windows installer usb because it was the only boot option.
        Now i cannot get into bios or boot menu, again. 😥
        i got lucky.
        • claws77
          • Apr 2024
          • 103
          • India
          #84
          i messed up, i reflashed the bios given by SMDFlea after reinstalling (fresh) windows, now its stuck at Asus logo, cannot go into windows or bios, 🤣🤣
          i looked it up - google response boot order issues, but i cannot do anything​
          • claws77
            • Apr 2024
            • 103
            • India
            #85
            now it goes to windows automatically, idk wth is going on, bios still does not work!
            all i did was inserted my windows installer usb in hopes of trying to get reinstall windows again!
              • 21381
              The bios is ok, you won`t get any better than that. Try installing RST drivers during install https://www.asus.com/support/faq/1044458/ .Please post in your other topic, it`s no longer a bios problem.
              • mon2
                • Dec 2019
                • 14456
                Adding a few bios images for the GL553VD as requested.
                • c.daniel
                  • Mar 2017
                  • 108
                  • Romania
                  #88
                  Hello. Asus GL553VD-FY009, bios busted after bios windows update failed
                  Now notebook is starting, but no picture on screen
                  SN H2N0CV179585084
                  Can you guys make me an revive? Thank you very much.
                    • 21381
                    SN H2N0CV179585084
                    What model number does it say on the barcode sticker - https://www.badcaps.net/forum/troubl...10#post3307010
                    • c.daniel
                      • Mar 2017
                      • 108
                      • Romania
                      #90
                      Mate, it not say anything, because i did NOT take out mainboard, notebook has to be resolved low on money, like nothing...
                      So. i search on this 5 pages of bios, and search inside file for therms "GL553VD" and i picked file named "Asus Rog GL553VD-F1 Rog GL553VD-F1_bios-version-302"
                      Write it, it's working perfect.
                      But, this file has SN named generaly "SSN1234567890123456", and because i did NOT know at what adress i find DMI, i proceed like this:
                      - i search in my messed up bios for original SN "H2N0CV179585084" and i find it from 2706D0 - 271D00
                      - i decided that DMI region is from 270100 - 271FF0, copy it in the new working bios, write it, BUT, in bios SN is still show the general one "H2N0CV179585084"
                      Please tell me how to find in future where is located DMI in a bin file.
                      Thank you.
                        • 21381
                        Thank you.
                        Search for CNFG (and/or GPNV) and find the start offset 270000 .The length is 10000 ,the end offset is 27FFFF. With some of the newer asus models the DMI the length is 8000
                        • c.daniel
                          • Mar 2017
                          • 108
                          • Romania
                          #92
                          Thank you very much SMDFlea
                          • razor_amd
                            by razor_amd
                            12-15-2020, 07:07 PM
                          • grimacelord
                            by grimacelord
                            07-10-2025, 02:52 PM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
                          • MotherTeresa
                            ASUS ROG GL552VW v2 - BIOS check/repair
                            by MotherTeresa
                            Hello Could someone who knows about BIOS take a look at the attached dump. Laptop AUSU ROG GL552VW with nVidia N16P 4GB and i5 CPU.
                            I used to change GPU in the laptop, and it worked without problems for a few years. My 9-year-old daughter uses the equipment, yesterday it worked, today she says it won't start. I checked and it hangs on the ASUS logo, you can't enter BIOS (it worked once).
                            Disconnecting all peripherals, including the keyboard, resetting BIOS with jumpers under RAM, changing RAM does nothing, it still hangs on LOGO.
                            I installed a different BIOS from this model to...
                            06-29-2025, 07:30 AM
                          • throwaway327
                            by throwaway327
                            Model No: RC72LA
                            Serial No: SBNVKD001014459
                            06-18-2025, 05:52 PM
