Panasonic CF-54 Bios Password
  • splus11
    • May 2016
    • 74
    • Poland
    #341
    Re: Panasonic CF-54 Bios Password
    Panasonic unlocked. Thank you for your help.
    Peter
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      #342
      Peter
      You're welcome. Enjoy
      Become a Badcaps supporter
      Thanks to all supporters.​
      • newCap12
        • Aug 2023
        Can someone please get the password taken off of this read. It would be greatly appreciated. It's a CF-54CY003ZZ with a MX25L12873F chip.
        Please let me know if you need any supporting documents. I am more than happy to donate for the cause.
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #344
          Here you are - unlocked:
          • newCap12
            • Aug 2023
            Thank you. I ended up dumping the chip and it worked. I was able to get to the BIOS screen however my USB was not showing as a bootable device.
            After playing around with the settings and not getting anywhere I wanted a clean slate so I chose restore defaults not knowing it would pull the previous BIOS save from the HDD... I'm going to take it apart again tomorrow
            Any advice on what the next steps are after getting to the BIOS screen? I did not see the HDD to boot off of and it was not picking up the Hirens Boot CD USB. My plan was to get in there and use Hirens to wipe the passwords on the Windows accounts.
            Is it possible to decode what the password was on the original dump and move forward from there in it's current state?
            Thank you once again.
            • newCap12
              • Aug 2023
              Found out the .iso was corrupted after verifying the file's integrity. I ended up putting a new SSD in since the current one in the laptop was encrypted and would not format no matter what software I used.
              I appreciate the help for getting into the BIOS.
              • imran421
                • Apr 2020
                • 74
                Please remove the bios password.
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #348
                  Here you are
                  • imran421
                    • Apr 2020
                    • 74
                    no go. completely blank
                    • imran421
                      • Apr 2020
                      • 74
                      no power as well. Any help please
                      • volinakis
                        • Jan 2021
                        • 2728
                        • N/A
                        #351
                        check if you solder well your bios chipset. Also try this.
                        • imran421
                          • Apr 2020
                          • 74
                          Powers on blank screen. Can you please recheck?
                          • volinakis
                            • Jan 2021
                            • 2728
                            • N/A
                            #353
                            it means you failed to dump your bios properly. Write back what you did save and see if laptop is working.
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1224
                              • France
                              #354
                              try
                              • thefix.pk
                                • Oct 2018
                                • 0
                                • Pakistan
                                #355
                                any one please clear me this bios for me display come very late
                                • volinakis
                                  • Jan 2021
                                  • 2728
                                  • N/A
                                  #356
                                  try
                                  • imran421
                                    • Apr 2020
                                    • 74
                                    Originally posted by Maxpower3
                                    try
                                    this one worked
                                    • Maxpower3
                                      Bad Veteran
                                      • Feb 2018
                                      • 1224
                                      • France
                                      #358
                                      this one worked
                                      normal, I know that the 01 at the end must remain. It is useful for boot logo
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #359
                                        No, I know what you mean but it's not the case here, imran421 just failed to program the chip properly in its first attempt. The bios should work just fine even without "the 01 at the end".
                                        • Maxpower3
                                          Bad Veteran
                                          • Feb 2018
                                          • 1224
                                          • France
                                          #360
                                          you're probably right, just a silent start indicator.
                                          The main thing is that it is successful
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • longmt1990
                                            Panasonic Cf-w5 bios password remove
                                            by longmt1990
                                            Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                                            I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                                            Please help me remove bios password.
                                            Thank you so much
                                            07-06-2025, 10:50 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
