asus s301LA,
  • maurovalero
    • Sep 2018
    • 69
    • colombia
    asus s301LA,
    Any have bios dump s301LA MB REV 2.2
  • marcin02152
    • Oct 2014
    • 134
    • Polska
    Re: asus s301LA,
    Try
    https://www.badcaps.net/forum/showth...ghlight=s301LA
    • maurovalero
      • Sep 2018
      • 69
      • colombia
      Re: asus s301LA,
      marcin0 thx a lot works perfectly
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
