Panasonic CF-H2 MK1 Bios bin
  • medinfo
    • May 2016
    • 331
    • Morocco
    Panasonic CF-H2 MK1
    Bios = 8 MB
  • on/off
    • Oct 2016
    • 333
    • Indonesia
    Re: Panasonic CF-H2 MK1 Bios bin
    Did you test from your old thread?
    https://www.badcaps.net/forum/showth...t=panasonic+CF
    • medinfo
      • May 2016
      • 331
      • Morocco
      it's a bios 16mb but i need a bios 8mb for mk1
      • on/off
        • Oct 2016
        • 333
        • Indonesia
        Many good bios expert here, usually them will asking your backup, for purpose comparing (also for educating) with official or even from dump backup.
        Reno (rioreno) where are you?
        • medinfo
          • May 2016
          • 331
          • Morocco
          it's a backup of the bios with password
          • medinfo
            • May 2016
            • 331
            • Morocco
            Nothing ??
              • 21861
              Try this one .
              • medinfo
                • May 2016
                • 331
                • Morocco
                thank you, but it still asks for the password
                  • 21861
                  Try this new one, i think i got it right this time.
                  • medinfo
                    • May 2016
                    • 331
                    • Morocco
                    ok I will try
                    • imranromi
                      • Jan 2015
                      • 1290
                      • Pakistan
                      Try this and reply.
                      • medinfo
                        • May 2016
                        • 331
                        • Morocco
                        power on but no display, thank you for your help
                        • medinfo
                          • May 2016
                          • 331
                          • Morocco
                          i will try imranromi thank you
                          • medinfo
                            • May 2016
                            • 331
                            • Morocco
                            Originally posted by imranromi
                            Try this and reply.
                            thank you very much it works with no password in boot
                            • medinfo
                              • May 2016
                              • 331
                              • Morocco
                              thank you very much for your help SMDFlea
                              • Miki81
                                • Jun 2023
                                • Sweden
                                what utility to use for flashing ?
                                • AquaMan Ua
                                  by AquaMan Ua
                                  05-17-2025, 09:40 AM
                                • aa10aa10
                                  Panasonic Toughbook CF-33 mk1 BIOS repair
                                  by aa10aa10
                                  Good day,
                                  I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                  I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                  01-21-2025, 06:13 AM
                                • pirati
                                  by pirati
                                  Yesterday, 04:20 PM
                                • Vesko356
                                  by Vesko356
                                  08-11-2023, 03:27 AM
                                • James Jackson
                                  Panasonic CF-20G0247VM BIOS Bad Flash Help
                                  by James Jackson
                                  I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
                                  Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
                                  05-01-2025, 11:28 AM
