Vaio VPCZ-Fan on full speed after flash BIOS
  • CornholioGSM
    • Feb 2014
    • 265
    • CZECH
    i have special problem. By me is Vaio VPCZ12X9E with MBX-206 mainboard.
    I have smashed original bios by modding for enable hidden settings...and i have no backup So i have found bios dump on internet for same MBX-206 mainboard and then i have flash it to bad one. Thats okay - notebook starts without problem and all is working....BUT after power on fan goes on full speed ...and still in full speed in bios settings and in windows too
    I have checked dust inside and all is clean...thermal compound is new.
    My idea is - maybe is some different within EU and USA version?
    Because dump is from VPCZ117CF and my vaio is VPCZ12X9E.
    Now i have modded installed bios for enable more settings - inside is now settings for fan speed - but this settings does nothing.
    I have attached my bios dump.
    Can anyone help me?
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Vaio VPCZ-Fan on full speed after flash BIOS
    now you should try various bios dumps to find a working one.
    unfortunately, the original Bios for VPCZ12X9E does not exists on the Sony website anymore. So you have to wait till someone uploads it here.
    There is also one in the following thread that you can try:
    https://www.badcaps.net/forum/showth...hlight=MBX-206
    The poster said: "it works like a charm" , but it does not belong to VPCZ12X9E.
      • 22276
      This post should be in the bios requests sub-forum.
      Anyway...
      The bios linked to by @caspian was an older one,Ver:R1180C3 ,i`ve merged the R3031C3 bios update into it and cleaned the ME area,it should be ok , but without the mods .The VPCZ1 models all use the same bios,the DMI area is different.
      Did you follow the guide at notebookreview? http://forum.notebookreview.com/thre...473226/page-44
      The DMI info is at 34B000 - 34B2BF for anyone else who wants to edit their own DMI into this bios.
      • CornholioGSM
        • Feb 2014
        • 265
        • CZECH
        Originally posted by SMDFlea
        This post....
        good...with this bios dump looks overything good...and is silence
        ...i go test to mod it
        EDIT...yesss after modding all works too...soo my finded bios dump was bad.
        Thankssss
          by Vesko356
          08-11-2023, 03:27 AM
        • abhorsen
          Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
          by abhorsen
          Hey guys,
          Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
          Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
          Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
          07-06-2023, 10:22 AM
        • AquaMan Ua
          Problem with PANASONIC CF53 laptop after changing BIOS settings
          by AquaMan Ua
          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
          05-17-2025, 09:40 AM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
